Group Buys Members group buys
NDK NZ2520SDA oscillators group buy
Old 30th November 2017, 03:11 AM   #151
Ben Mah is offline Ben Mah  Canada
I suggest practice. SMD resistors are cheap for practising your hot air soldering.
Old 2nd December 2017, 10:37 AM   #152
Lorien is offline Lorien
Hello Jack! Thank you for confirming the delivery of your SDAs! If it does help you, I'm using both soldering iron and hot air station to solder those tiny parts!
The temp on both is set at 330 degrees centigrade but frankly I have no clear idea if the actual temp is matching the one displayed on the gears. Either way, I'm usually cleaning the place where the oscillators will be soldered, in case there was an older solder there, especially the ones mostly based only on tin.
I'm mostly using the Sn63/Pb37 solder wire due to low melting point and solder wick to clean up the old solder. After that I'm cleaning the place with isopropyl alcohol and put some new flux in there. After that I'm using the soldering iron with a small tip to make four "new" solder bumps on the places where the new part will be soldered. The idea is to keep the bumps equal so that your oscillators be soldered as parallel with the PCB as possible.
Do not make those bumps too high because you can end up with shorts! Not to mention that the metallic package of the NDK oscillators will love to take a 'taste' of that melted solder!
After that, the NDK oscillator will be kept in place with tweezers and use hot air gun to heat up the place. Remember to NOT keep the air nozzle straight above the part! You have to heat up the surrounding copper pads as well by moving the nozzle in circular form. When the bumps under the SDA oscillators are melt then your part will get self-centered above the footprint.
Basically you can move the part with hot air flux. Speaking of air flux, my station is set around a scale of 2.5 from 6 (maximum).
As you can see I'm not using solder paste of any kind because in my experience, the solder paste does not make a good bundle with hot air station! there are some exceptions though but most of the good results are involving preheaters as well... but, in my opinion, you don't need those for your work!
I hope it helps!
EDIT: I forgot to say that the nozzle tip I'm using is rather small, I guess it has the diameter of the NDK SDA itself. This way I can work on small areas without affecting the surrounding parts too much (by temperature). If the nozzle you're using does have a bigger diameter then you can compensate by rising the value of the air flux and then by rising the temp.
Contact link for WaveIO USB-to-I2S/SPDIF board.
Old 2nd December 2017, 02:02 PM   #153
jacklee is offline jacklee  Hong Kong
Lorien: Thanks for the tips.
I am happy to report that soldering the SDAs are successful!
I took a different approach as my hot air rework station is still in transit so I tried using my Hakko hot tweezers to solder the SDAs. I tined all 4 pads with solder, placed the SDA on top, and then use the hot tweezers to clamp the SDA to place it in-place while heating up the pads at the same time.
The SDAs survived despite being heated by the hot tweezers at 350C directly for about 5 seconds. While I am at it I also soldered two Crystek 957 - super easy by comparison.
I verified the oscillators by connecting them to a lab power supply at 3.3V and then used a scope to check the output (see attached).
One question: The Ian adapters have three sets of pads on the underside for decoupling caps. I installed just one cap of 100nF supplied with the adapter. Is that sufficient?
Old 8th December 2017, 12:33 PM   #154
m.massimo is offline m.massimo  Italy
I'd like to thank Lucian for the excellent job at replacing NDK in my WaveIO.
Old 11th December 2017, 08:51 AM   #155
Hello Massimo! With welcome!
Old 4th January 2018, 12:29 AM   #156
kvl is offline kvl  Taiwan
NZ2520SDA Group buy (for 45.1584 MHz and 49.152 MHz):
1. Lorien - 10 pairs
2. M_Baou - 1 pair.
3. sontero - 1 pair.
4. kvl - 2 pairs
Old 10th January 2018, 05:52 PM   #157
@ kvl: you have Paypal invoice per your request!
One additional note: I forgot to update the prices for SDAs on this GB: one oscillator is 14 USD and shipping will be 4.2 USD. To make things easier for me I'll express the total amount in Euro.
Kind regards,
L
Edit: above prices include Paypal and VAT charges.
Old 10th January 2018, 11:49 PM   #158
Now payed
Thanks!!
Old 11th January 2018, 01:28 AM   #159
wlowes is offline wlowes  Canada
wlowes's Avatar
Default adding wlowes GB
2. M_Baou - 1 pair.
4. kvl - 2 pairs
5. wlowes - 1 pair
Old 11th January 2018, 07:27 AM   #160
I decided to mix things together to be easier for anyone to read and update their preferences!
NZ2520SDA Group buy
(for 22.5792 MHz, 24.576 MHz, 45.1584 MHz and 49.152 MHz oscillators):
1. M_Baou - 1 pair of 4x
2. sontero - 1 pair of 4x
3. kvl - 2 pairs of 4x
4. wlowes - 1 pair of 4x
You can express your request whatever you want/like!
Kind regards,
L
Edit: @ kvl: got it, thank you!
NDK NZ2520SDA oscillators group buyHide this!Advertise here!
Low jitter crystal oscillators (NDK) Alexandre Swap Meet 1 20th February 2015 05:56 AM
Group buy how to: AmpUtator Group Buys 1 15th September 2013 05:49 PM
Tea-Bag's IXYS Depletion Mosfet Group and SemiSouth R100 JFET group buy. Tea-Bag Group Buys 330 20th May 2013 01:03 PM
Group buy for very low jitter oscillators jwb Group Buys 2 27th January 2008 10:17 PM
