We keep two threads for the RTX6001.
This that was for the GB of unit and other DIY Audio Analyzer with AK5397/AK5394A and AK4490
Because, the GB has ended and I think so that all the members that participate to it have the unit...isn't better to keep our questions to the other thread at the "Equipment and Tools"?
OK, I made it working properly.
There's still some "magic" involved I have simply copied the configuration file from the desktop (working well) to the notebook (showing garbage). After some tricks (WinAudioMLS crashed a few times when I tried to load that saved configuration - there is some issue in WinAudioMLS when the sample rates do not match), I've got it running exactly the same way, as it runs on the desktop - no "garbage", even at 192KHz sample rate.
Bit depth?
Hi Lemon,
Good point, and I agree.
Here is the thread we should be using:
I'll lock this thread and have everyone continue in the proper thread. The link takes you to the first post, just select the last page and start there.
I can't move the posts over as it would confuse the living heck out of everyone. Sorry about that.
-Chris
