Group Buys Members group buys
GB for RTX6001 Audio Analyzer with AK5394A and AK4490
Closed Thread
Old 13th January 2018, 07:30 AM   #771
soongsc is offline soongsc  Taiwan
soongsc's Avatar
I have done all the Mac portion you mentioned. Even the basic speaker config option in the Audio MIDI setup app does not play sound to identify speakers. I am in the process of moving Windows based measurements to BootCamp on the MacBook as well. Other USB soundcards work fine. I will try the RTX later.
Hear the real thing!
Old 13th January 2018, 11:27 AM   #772
soongsc's Avatar
Default GB for RTX6001 Audio Analyzer with AK5394A and AK4490
Sounds dumb, but I did not change the power line to the right voltage.GB for RTX6001 Audio Analyzer with AK5394A and AK4490 Sounds amazingly neutral on first listening. Well damped. Using the recommended USB cable, there is totally no trace of sonic signature associated with longer USB cables I have tried with other devices.
Switching to my usual USB cable, the lower frequencies and the dynamics seemed be have a more weight into the music.
So I would be interested to see if measurements will show differences.
Old 13th January 2018, 12:11 PM   #773
cwtim01 is offline cwtim01  Hong Kong
cwtim01's Avatar
> Well damped
The RTX has an output impedance of 50R (single-ended) or 100R (balanced), if there is no headphone amp following the RTX, it'll have a very low damping factor - less than 1 for commonly found 32R phones.
Old 13th January 2018, 12:21 PM   #774
soongsc's Avatar
You know, I really to not fully understand how the output source impedance and load impedance ratio relates with the settling time of a signal. My current comments are really how I perceive how sounds die out listening through my active speakers.
Old 13th January 2018, 05:03 PM   #775
JensH is offline JensH  Denmark
Originally Posted by soongsc View Post
I am wondering, what data format should the RTX received? Integer or floating point?
Definitely not floating point! It should be either 16, 24 or 32 bit fixed point.
So are you saying that you connected it to a 110 V line voltage, but with the unit set to 230 V?
I have actually not tried it. I could imagine that it will work to some extent, but you may get an increased hum level.
Doing it the other way around will probably blow a fuse or two.
I wouldn't expect the length and type of cable to make any difference at all, as long as data transmission is error free.
If you use an amplifier after the RTX6001, the output impedance of the RTX6001 is not terribly critical. I assume that in this case the amplifier input impedance is relatively high, like 10k or higher.
Connecting it directly to headphones is a different matter of course.
Old 14th January 2018, 10:35 AM   #776
soongsc's Avatar
I am playing around with REW on the MacBook, it always shows 16bit. Canít find a way to show 24bit. Only two sample rate selection. Is this the same limitation on the Windows version?
Old 14th January 2018, 10:46 AM   #777
PaulBC is offline PaulBC  Taiwan
You need to install the beta version of REW.
Old 14th January 2018, 10:55 AM   #778
In the Windows version you can select 44.1, 48, 88.2, 96 and 192 kHz in REW. 176.4 kHz does not seem to be supported by REW, but that is also the case with other applications and hardly a big issue. It is supported by the RTX6001 though.
Old 14th January 2018, 11:00 AM   #779
soongsc's Avatar
Thanks! I will get the OSX beta version to try.
Old 14th January 2018, 01:11 PM   #780
soongsc's Avatar
USB cable difference
Closed Thread
GB for RTX6001 Audio Analyzer with AK5394A and AK4490Hide this!Advertise here!
DIY Audio Analyzer with AK5397/AK5394A and AK4490 JensH Equipment & Tools 2324 15th July 2018 07:32 PM
Mirand audio - AK4490 USB Dac with DSD support ravid Swap Meet 2 23rd July 2016 04:26 PM
Audio Precision ATS-1 Audio Analyzer works but Ugly Zero Cool Swap Meet 12 14th May 2016 04:02 PM
NTi Audio XL2 Handheld Audio Analyzer Fredenando Equipment & Tools 0 18th April 2010 03:04 AM
AKM AK5394a TobWen Digital Source 41 31st December 2003 06:18 PM
