Group Buys Members group buys
GB for RTX6001 Audio Analyzer with AK5394A and AK4490
Closed Thread
Old 12th January 2018, 08:06 PM   #761
NicMac is offline NicMac  Italy
NicMac's Avatar
I connected my HD650 headphones directly to the RTX and selected the RTX in the System Preferences Sound control panel (iMac). Works right away.
However, unfortunately, volume control is limited to the physical switches on the RTX... A three-step volume control is a bit rough even for a tolerant dane like me
How come software like ARTA, REW etc. can adjust the output, but "music" software like iTunes etc.cannot?
The best USB DAC in the world, but with a 3-step attenuator
P.S. To my personal taste the lowest output level (-20dB) is actually quite pleasant
The 0dB is party time, and I did not even try the 20dB as I fear for my headphones.....
Old 12th January 2018, 11:24 PM   #762
soongsc is offline soongsc  Taiwan
soongsc's Avatar
Thanks, then I will just need to figure out what’s wrong on my setup.
Hear the real thing!
Old 13th January 2018, 04:36 AM   #763
cwtim01 is offline cwtim01  Hong Kong
cwtim01's Avatar
The first set of fix PCB that RTX sent me was loss in transit, but their support is great and they sent me a second set, which finally arrived yesterday. I'm impressed that they even prepare all the required wires with spares.
So I followed the instruction published by JensH and get the mod done today, it passed the test mentioned in post #686 and everything is working as expected. Now I'm tempted to try the transformer rotation mod of PaulBC.
I also tried listening to the RTX as DAC, works great with JRiver Media Center and it sounds very similar to my Lynx Hilo DAC, a very clean and neutral sound. I use a balanced headphone amp after the DAC, so volume control is not an issue.
Old 13th January 2018, 04:39 AM   #764
soongsc's Avatar
Has anyone tried the unbalanced outputs? Can sound play through these?
Old 13th January 2018, 05:34 AM   #765
soongsc's Avatar
Not playing any sound, even when checking the channels in the Audio Midi setup utility, no sound comes out. I am going to pull out the other unit to try.
Old 13th January 2018, 05:45 AM   #766
JensH is offline JensH  Denmark
@cwtim01
Looks good
Having a headphone amp is a good idea. I agree that 20 dB volume steps are a bit rough
@soongsc
The unbalanced outputs are just the (+) wire of the balanced output. So compared to the balanced output, the signal will be 6 dB lower. And the impedance is 50 ohm.
Old 13th January 2018, 06:29 AM   #767
soongsc's Avatar
Default GB for RTX6001 Audio Analyzer with AK5394A and AK4490
I am out of ideas. Two units no sound on two MacBooks. I checked the Audio Midi setup app while playing, when I start to play, the playback device symbol will jump away from the RTX, when I stop playing, it will jump back to the RTX. This is weird!
I am wondering, what data format should the RTX received? Integer or floating point?
Old 13th January 2018, 07:14 AM   #768
mbrennwa is offline mbrennwa  Switzerland
mbrennwa's Avatar
The audio analysis tools adjust the amplitude of the test signal before sending the signal to the audio hardware. iTunes does not do that, but leaves the volume control to the operating system and the audio hardware itself. iTunes just tells the music playback system to set the volume accordingly. This function is implemented in almost all "soundcards" (often on the DAC chip, sometimes in the analog output stage).
[ audioroot.net | hifibau.ch ]
Old 13th January 2018, 07:17 AM   #769
soongsc's Avatar
Jriver actually allows doing it either way.
Old 13th January 2018, 07:23 AM   #770
mbrennwa's Avatar
Did you try with using standard Apple software only? Maybe Jriver messed up / blocked the USB sound interface somehow? I had a similar issue with REW once.
I'd turn everything off (computer and RTX), disconnect USB cable, make sure no other audio intefaces are connected and no AirPlay devices within reach, restart computer and RTX, reconnect USB, and then try with iTunes without touching any other software first.
The next step would be to try with a non-Mac computer.
Closed Thread
GB for RTX6001 Audio Analyzer with AK5394A and AK4490Hide this!Advertise here!
DIY Audio Analyzer with AK5397/AK5394A and AK4490 JensH Equipment & Tools 2230 Today 01:12 AM
Mirand audio - AK4490 USB Dac with DSD support ravid Swap Meet 2 23rd July 2016 04:26 PM
Audio Precision ATS-1 Audio Analyzer works but Ugly Zero Cool Swap Meet 12 14th May 2016 04:02 PM
NTi Audio XL2 Handheld Audio Analyzer Fredenando Equipment & Tools 0 18th April 2010 03:04 AM
AKM AK5394a TobWen Digital Source 41 31st December 2003 06:18 PM
