Group Buys Members group buys
xrk971 Pocket Class A Headamp GB
Old 14th June 2018, 09:55 PM   #1841
jebivetar is offline jebivetar
Originally Posted by xrk971 View Post
I mistakenly thought the parts I had were thin film, when in fact they were thick film.
yup.
what are ideal electrolytic alternatives for the 100uF spot on the capmx?
there's a worldwide smd cap shortage and i don't think i even see any x7r 25V 47uF or higher MLCCs on digikey or lcsc.
i'm currently using a 100uf rubycon yxg, but not sure if there's something better suited.
Old 14th June 2018, 11:08 PM   #1842
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
Try looking for tantalum in SMD for larger values. Still available and fine for non low ESR requirements.
XRKaudio https://www.etsy.com/shop/XRKAudio
Old 16th June 2018, 08:03 PM   #1843
Alright, some more questions about the resistors - the revised values specifically.
In the original low impedence BOM, R6 is 47R.
The first time you mention your revised low impedance resistor network it is 1R:
R3 = 820R
R4 = 47R
R5 = 220R
R6 = 1R
Some posts later you describe it again in a reply to someone but mention only R3 through R5, and leave out R6.
R3=820R, R4=33R, R5=220R
What's R6 in the revised network?
Old 16th June 2018, 09:30 PM   #1844
Got Foam?
xrk971's Avatar
R6 is the so-called gate stopper that is there to absorb any oscillations in the gate of the MOSFETs. It could be 0R, but I would leave it at 47R to be safe. I don't know what I was thinking if I ever suggested using 1R. Maybe 10R lowest. But my recommendation is leave at 47R.
R3 should be about 1k or 1k1 - adjust it to get the correct voltage at the source (pin 3) of the MOSFET. The best value is 1/2 of Vcc, but adjusting it too much also changes the bias through the JFET. If you are within 0.5v of 1/2Vcc, leave it alone.
R4 adjusts the relative H2 to H3 distortion (larger R4 will be greater H3 but lower overrall THD), but be careful as it also changes bias current - higher R4 is higher bias current. One of the most effective ways to decrease THD and keep a good H2/H3 profile is to use a voltage regulated DC step up for the power supply and adjust so that Vcc is about 18.2v. If you monitor the FFT in real time as you adjust, you will see the optimum place to be. Ideally R4 is somewhere between 33R to 52R, typically, even 39R could be a sweet spot.
xrk971 Pocket Class A Headamp GBHide this!Advertise here!
BF862 based SE Class A Headamp without the HEAT xrk971 Headphone Systems 513 12th April 2018 08:44 AM
FS: F5X GB chassis and all GB parts Studley Swap Meet 6 21st May 2013 11:47 AM
Midgård, compact, low distortion, high quality, Class A Lateral FET headamp Neutrality Headphone Systems 23 12th March 2013 05:21 PM
Another Class A headamp idea Dxvideo Solid State 3 19th November 2007 08:08 AM
Pocket pre-amp & headamp digi01 Chip Amps 11 10th October 2004 12:49 AM
