Group Buys Members group buys
CRC Power Supply (Class A amplifier)
Old 6th October 2017, 09:15 AM   #671
Project16 is offline Project16  France
Project16's Avatar
The power or supply voltage of an amplifier is irrelevant and a 15V powered amplifier will be wired as a 50V power supply.
The major problem I think is that a lot of people confuse or associate grounding (earth) and masses (GNDs) and it has to be said that they are very different things and should never be connected together.
Then the GND must be carefully wired.
That's my point of view.
Old 6th October 2017, 09:28 AM   #672
Project16's Avatar
Originally Posted by cl00sed View Post
You mean to use chassis ground to home ground?
YES.
The yellow and green wires are also connected to the earth connection if they exist on a transformer.
Old 6th October 2017, 09:36 AM   #673
Project16's Avatar
If you connect the ground (GND) of an amplifier to the chassis with the ground (earth) you are exposed to all the noise nuisances transmitted by the mains and there are many.
Old 6th October 2017, 02:08 PM   #674
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
Yes, that's why there are filters for the earth ground, DC blockers, etc. but commercial amps have to do this via GLB or NTC as it is required by electrical code for safety. Note that forum rules prohibit the recommendation by members to set up a system that doesn't follow electrical code for safety when it comes to wiring up mains.
Look at the Pass F6 PSU above, it follows code and connects earth GND to chassis GND and to PSU power GND via an NTC. That follows electrical code and has no hum. Can a similar arrangement be made for the dual CRC and dual Trafo? I haven't been able to find it yet.
XRKaudio https://www.etsy.com/shop/XRKAudio
Old 6th October 2017, 03:39 PM   #675
CitizenKane is offline CitizenKane  Germany
CitizenKane's Avatar
Hi Prasi,
got my boards today.
Thanks a lot
Jo
Old 11th October 2017, 05:51 PM   #676
prasi is online now prasi  India
prasi's Avatar
Hi Jo,
Thanks for your confirmation.
regards
Prasi
My revamped site https://sites.google.com/site/analogdesign1234/
Old 12th October 2017, 03:43 PM   #677
prasi's Avatar
gtose, Cobra2, brookhart995
could you kindly confirm if you have received the PCB's.?
Also I dont seem to have the PCB receipt confirmations from Joca and h-wan . Could you let me know the status?
regards
Prasi
Old 12th October 2017, 03:58 PM   #678
gtose is offline gtose  United States
I received mine!
Old 12th October 2017, 04:42 PM   #679
Joca is offline Joca  Portugal
Sorry. I've received mine. Already working with 0.0mvac ripple.
Nice work in the pcb. Thanks
Old 12th October 2017, 05:31 PM   #680
prasi's Avatar
Thank you Joca... Glad that you are very happy with results. Credit for the design goes to Project16.
regards
Prasi
CRC Power Supply (Class A amplifier)Hide this!Advertise here!
CRC power supply cap addition valvesound Pass Labs 9 2nd December 2013 05:27 AM
CRC power amp supply pjpoes Solid State 46 1st November 2013 05:04 AM
CRC Power Supply Resistor Rating weslito Power Supplies 3 17th February 2013 08:13 PM
CRC Power Supply design, help me understand it pjpoes Power Supplies 4 4th March 2007 04:46 PM
Aleph X CRC Power Supply for 60 W amp lgreen Pass Labs 3 19th December 2004 12:52 AM
