Group Buys Members group buys
CRC Power Supply (Class A amplifier)
Old 13th September 2017, 02:39 PM   #571
prasi is offline prasi  India
prasi's Avatar
Originally Posted by prasi View Post
Hi Pierre,
There are no boards left. However I have ordered 50 more as I have been getting some requirements through PM and for local sale. Price will be 5.3 USD per PCB. PCB will be available with me in another 18 days approx.
regards
Prasi
Here is the list
bigaudioscotto 2 nos
vj_audio 2 nos?
ajit 2 nos
Pierre 4 nos.
received another 50 CRC boards today.
For those as per above list and also anyone else, Please send me a PM with your name, address, postal code, Paypal address.
Old 15th September 2017, 06:10 AM   #572
xrk971 is online now xrk971  United States
xrk971's Avatar
I just built up two more PSU's. This is the second gen layout and it works well. I am using 22mF 35v caps and 2x 0.47R Panasonic 3W metal film. Diodes are all MUR880's from Mouser. I have to say, these PSU's are just as complicated and time consuming to build as an amp. Nice PSU, but sure uses a lot of my stash of film caps!
CRC Power Supply (Class A amplifier)-crc-class-psu-build-jpg
I will probably use this for my main Class A PSU for various amps from here on out. M2, DLH, F5, Babelfish J, etc...
XRKaudio https://www.etsy.com/shop/XRKAudio
Old 15th September 2017, 07:23 AM   #573
prasi's Avatar
As usual, nicely done. Yep sure does use plenty of small things like fastons, plastic sleeves, insulating pads, film caps. Etc.
Have you tried building one with Quasimodo components with default values or as per Quasimodo procedure?
Old 15th September 2017, 02:30 PM   #574
manniraj is online now manniraj  India
One thing I have noticed is that the pads especially of the smaller components like the LED come off easily with desoldering/soldering couple of times with a 25w iron, otherwise very nice VFM boards
Old 15th September 2017, 04:05 PM   #575
prasi's Avatar
Thats strange, it would be a problem with 35um and smaller pads. However this board has 70um and comparatively big pads.
One should keep both pads heated while pulling out, if one pad is cold, it stresses that pad.
Old 15th September 2017, 04:26 PM   #576
Hmm I used a single solder while heating and also underside of the PCB to pull out the LED which was reversed. So the underside pads came out but resoldering the LED with the correct orientation worked without any issues.
Old 15th September 2017, 05:30 PM   #577
prasi's Avatar
Ok I get it. Do have a look at some desoldering videos on youtube, especially by adafruit (funny guy!) and others. there is plenty of good info and plus it requires skill which comes with plenty of debugging of amplifier/pre-amp PCBs especially that have 8 pin, 14 pin IC and to-92 transistors (desoldering w/o damaging) on double sided PCB. De-soldering LM3886 soldered in small holes was a PITA the first time I did it.
Get the desoldering tools from aliexpress based on user reviews and no of orders.
You will be good to go.
BTW your PCB are shipped, also others who ordered, I shall share tracking info by tomorrow.
regards
Prasi
Old 17th September 2017, 02:54 PM   #578
xrk971's Avatar
Dual CRC PSU's now in Babelfish J project. With 400VA Antek 18VAC I am getting 1mV ripple no load. Pretty good - let's see what happens when 1.25amps flow. Fits a 3U Dissipante case perfectly.
Babbelfish J PCBs-img_7845-jpg
Babbelfish J PCBs
Old 17th September 2017, 05:51 PM   #579
prasi's Avatar
Babbelfish J PCBs
Nicely done, all the best for your Babelfish J project.!
Old 17th September 2017, 05:55 PM   #580
zman01 is offline zman01  Bangladesh
Looking good X.
CRC Power Supply (Class A amplifier)Hide this!Advertise here!
CRC power supply cap addition valvesound Pass Labs 9 2nd December 2013 05:27 AM
CRC power amp supply pjpoes Solid State 46 1st November 2013 05:04 AM
CRC Power Supply Resistor Rating weslito Power Supplies 3 17th February 2013 08:13 PM
CRC Power Supply design, help me understand it pjpoes Power Supplies 4 4th March 2007 04:46 PM
Aleph X CRC Power Supply for 60 W amp lgreen Pass Labs 3 19th December 2004 12:52 AM
Copyright ©1999-2017 diyAudio
