DAC ES9038 PRO Group Buys - Page 25 - diyAudio
Go Back   Home > Forums > Commercial Sector > Group Buys
Group Buys Members group buys
Old 20th March 2017, 04:38 PM   #241
akltam is offline akltam  Hong Kong
Dear Quanghao,
I was checking the voltage supply for each regulator. I found that the voltage labelled '3.3V_CL' only got 2.1V. I think this is the voltage to supply to the clock crystal.
What should be the correct voltage supply to the clock ? Is there something wrong ? I thought it should be 3.3V.
Alan
Alan
Old 21st March 2017, 04:51 AM   #242
bvtrinh is offline bvtrinh  United States
Default Thank you!
Originally Posted by akltam View Post
Here is a pic. Not very sharp
Thank you Alan! I was a bit confused about labeling the passive output boards as I/V since it is already in volts. Now everything is clear. Thank you Quanghao and Alan!
http://www.diyaudio.com/forums/attac...-es9038pro.gif
Old 21st March 2017, 05:11 AM   #243
Default Transformer questions
Hello Quanghao,
Does the transformer need to be dual secondaries or can I use a transformer with a center tap? Thank you!
Bao
Old 21st March 2017, 05:45 AM   #244
Send a message via Yahoo to quanghao Send a message via Skype™ to quanghao
Originally Posted by bvtrinh View Post
Hello Quanghao,
Bao
center tap . it is ok
thanks
Old 21st March 2017, 05:49 AM   #245
Dear Quanghao,
Alan
Here is the voltage for the Clock: 100MHZ. 3.3V
Find out carefully, check out C42. Maybe it caused the error! Or pins of LT3042 (IC5).
Touch or touch! Find it.
If you have capacitor 1206 = 10uF (C42), replace it!
thank you very much!
Old 21st March 2017, 07:44 AM   #246
Hi Quanghao,
The C42 is an SMD capacitor, there is no indication of the value of this capacitor. You want me to remove it ?
Alan
Old 21st March 2017, 08:50 AM   #247
Hi Quanghao,
Yes , remove it now and check 3.3 v.
Old 21st March 2017, 01:45 PM   #248
Hi Quanghao,
I removed C42 and the voltage is now 3.3V. Thank you.
Is this problem happening to all the boards you sent out already. If so, you need to inform all the other buyers to remove C42 from their boards. For those you have not sent out, you need to remove C42 for them.
Removing C42 is easy, first locate the indicator which said '3.3V_CL'. The LT3042 regulator next to this indicator is responsible for the 3.3V for the clock. C42 will be next to this regulator. To remove it, hold C42 with a plier, use a solder iron to heat one side of C42 for a few seconds, then C42 will come off easily.
Hope this helps all.
Alan
Old 21st March 2017, 02:09 PM   #249
[QUOTE=akltam;5026226]Hi Quanghao,
The problem you say, is not so. The C42 capacitor is not fault.
Cause the capacitor to fail in production.
Which is my experience.
You need to find another capacitor to replace: 1uF to 10uF / 6.3V.
thank you again !
Old 21st March 2017, 02:13 PM   #250
Myint67 is offline Myint67  Singapore
[QUOTE=quanghao;5026244]
Hi Quanghao,
thank you again !
Hi Alan ,
Thanks ,picture pls
DAC ES9038 PRO quanghao Quanghao Audio Design 14 14th February 2017 08:22 PM
How do group buys work? wtm111 Group Buys 4 25th February 2012 03:40 PM
Group Buys? JL889 Chipamp 0 9th November 2011 03:22 PM
Copyright 1999-2017 diyAudio
