What about C5, it is not used? If it not used I can use C5 for C1 and C2 , because is 10uf but is 10v, can I use this one?
I ordered 47uf for C4, but C4 is not used, can I use this one for C8 that is a 10uf cap that I forgot to ordered.
What about the question in post #418.
yes , all value you have you can use
C4,C5= parallel ( C4=0.1 uf, C5 = 10uf- 100uf)/
C1, C2 parallel ( C1== C5 = 10uf- 100uf)
All cap 10v is ok, becuae DC in need under 10V
C8=10uF, it is ok
I never use that, not test now. im not sure it is ok!
i see : LT3045 the sample Data Lt3042, it is may be can change, please try it and tell me the result@!
thanks
Hi do anybody know wich comperator was used for the very first Quang Hao dac?
Hi
Use, LMV7219
Br
Caad
Thank You very Much Caad You are my saver.Hi
Use, LMV7219
Br
Caad
- Group Buys
- DAC ES9038 PRO Group Buys
