Bruno Putzeys Balanced Preamp - Group Buy Part 3 - Page 2 - diyAudio
Go Back   Home > Forums > Commercial Sector > Group Buys
Group Buys Members group buys
Old 31st October 2016, 10:59 PM   #11
flashgo is offline flashgo  United States
Originally Posted by tfboy View Post
Added tentative pricing.
Can those of us outside the UK avoid the VAT?
Old 1st November 2016, 06:16 AM   #12
aradan is offline aradan  Singapore
Yes, it happened before
Old 1st November 2016, 06:46 AM   #13
tnargs is offline tnargs  Australia
1 board.
Each board is stereo. And you have two pairs of switchable inputs. All are Neutrik balanced XLR sockets.
Each board can take one set / pair of regulators. You don't need the Hypex ones, you can use regular regs if you want.
Thanks. I am trying to skim the articles and prior threads to find out how much gain does it have, if any?
Old 2nd November 2016, 02:17 AM   #14
Also, what are the maximum input signal and output signal?
Old 2nd November 2016, 12:33 PM   #15
tfboy is offline tfboy  United Kingdom
Yes, see first post amended with additional details.
Unity gain. See original thread here discussing technical points
Old 2nd November 2016, 01:01 PM   #16
It's not unity gain.
The gain is set by the vol pot.
The residual resistances at the vol pot extremes effectively sets the limits of the attenuation and gain.
Typically expect >>+40dB of gain at the top end and <-50dB of attenuation at the bottom end.
But the steepness of the rate of change towards the ends of the vol pot track make the last ten to twenty degrees of rotation nearly useless. Expect only the middle 200degrees of rotation be be an effective control and half of that will be gain (i.e. >+0dB)
I found all my range of volume adjustment was squeezed into less than 90 degrees of rotation. I changed to a stepped vol pot, to set the attenuations of the inverting opamp stage. Much better.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 2nd November 2016, 01:32 PM   #17
Oops. Thanks Andrew for detailing the reality. Long day yesterday at work...
Old 2nd November 2016, 03:50 PM   #18
I think voicb project led by Hans was aimed to address the volume control for bpbp. Together with maya controller or any ither diy controller it can make a good r2r gain controller
See the discussion here
Sent from my ONE A2003 using Tapatalk
Old 3rd November 2016, 08:42 AM   #19
Gerben is offline Gerben  Netherlands
Hi Andrew T,
Can you explain your solution? I have concerns about the consquences if the wiper of the pot fails. The maya solution is really neat but is overkill for what I'm looking for: just a replacement for the pot
I dont get the stepped volume pot. From other threads i read the suggestion for a 5Kpot +5K resistor, is this the change? Or did you use a stepped ladder switch and if so do you have suggestions for values using a 23 step switch like eg. this:
http://www.analogmetric.com/goods.php?id=1000
Thanks!
Gerben
Old 3rd November 2016, 10:31 AM   #20
I gave a few details, but not the resistor values.
I copied the ideas from the main thread.
I'll post more info over there.
regards Andrew T.
BPPBP - Bruno Putzey's Purist Balanced Preamp (well a balanced volume control really) Bertel Analog Line Level 528 11th January 2017 02:09 PM
Bruno Putzeys Balanced Preamp - Group Buy Part 2 tfboy Group Buys 400 31st October 2016 04:41 PM
WTB: Bruno Putzeys Balanced Preamp raelman Swap Meet 1 25th October 2016 01:57 PM
WTB: PCB for Bruno Putzeys Balanced Preamp Kim Bay Smidt Swap Meet 0 17th September 2016 07:28 AM
Bruno Putzeys Balanced Preamp - Group Buy Bertel Group Buys 393 25th February 2016 05:02 PM
Copyright 1999-2017 diyAudio
