New MINI ZEN Headphone Amp PCB group order... - Page 7 - diyAudio
Go Back   Home > Forums > Commercial Sector > Group Buys
Group Buys Members group buys
Old 30th June 2005, 04:14 PM   #61
steenoe is offline steenoe  Denmark
steenoe's Avatar
1. Where did you get the chassis?
I bought it from Elfa.se, the manufactorer is Teko in Italy:
http://www.teko.it/Eng/ENCLOSURES/frame.htm
The page works in frames so I couldnt link you directly:-( Its in the RF series, and called Dissipator. Check out the homepage for a local dealer.
2. Why the heatsinks? Was the chassis it's self not enough to cool the amps?
Because it was easier to mount the hole thing on the bottom. I didnt try to use the amp, with only the chassis as a heatsink. I did use the sidepanels of the chassis as heatsink for the reg's though. Have a look.
Its running 290 mA. The regs are the 2 small perfboards at the rear.
Steen
BTW I dont think the chassis itself will do the heatsinking
It runs fairly warm.
Old 30th June 2005, 04:21 PM   #62
steenoe's Avatar
I hope to finish mine soon, but I have been busy on my Krell Clone, Pass Mini-A, Hypex UcD-180's and the speakers all of them will be tried / used on...
That situation sounds quite familiar to me Just one more thing; The pinout of Q3 that digi01 uses, isnt the same as the ZTX450 and other normally used transistors! I used MPSA18 and had to twist the legs a bit
Check the designation on the board and compare it to whatever transistor you will be using
Steen
Old 7th July 2005, 11:03 AM   #63
r_jik45 is offline r_jik45  Japan
Hi all,
digi01,
Is a single power supply fine for two amplifiers?
Because, as others, I planned to make one per channel
Old 11th July 2005, 03:05 AM   #64
digi01 is offline digi01  China
digi01's Avatar
Send a message via MSN to digi01
hi steenoe,
Really nice building!what headphone are you using now?have you compare the difference of regulator psu and unregulator psu?
For the heatsink,I agree with steenoe.mine is a 3mm thickness,A4 paper size aluminium board for the chassis&heatsink.
to r_jik45,
I have run the Zen headamp with a couple of 35V unregulate power supply for dual mono,and a single 22V regulate psu for 2channel.I think the regulate psu make a preferable bass.
Z.
Old 12th July 2005, 02:58 PM   #65
digi01,
Thanks for your reply.
Old 12th July 2005, 10:10 PM   #66
steenoe's Avatar
I have a pair of Beyerdynamics DT880. I didnt compare the reg psu to an unregulated, since I had this regulated supply made allready. Just had to remove one Zener each side to get 24V.
The amp sounds fantastic. I didnt do any mods to make it fit the Beyer's. They are higher impedance than Grados, but that doesnt seem to be a big concern.
Steen
Old 13th July 2005, 06:35 AM   #67
tortello's Avatar
The amplifier is quite universal, even if some "faces" of its sounds were "cutted" to obtain an happy marriage with Grados.
Which are quite demanding towards electronics...
Marcello
Old 13th July 2005, 05:43 PM   #68
steenoe's Avatar
Hi Tortello
Thanks a lot for this fine piece of work It sounds just great.
Yep, I guess you are right about that The Beyer's never sounded better.
Steen
Old 13th July 2005, 07:49 PM   #69
tortello's Avatar
Hello Steenoe
thank you for your nice remarks.
Today about 200 amplifiers have been built, at least from the feedback I received straightly from the builders.
Sooner or later there will be an improved version of this amplifier, as soon as time will permit to develop some ideas.
Anyway... happy that you found it pleasant!
All the best from Italy
Marcello
Old 13th July 2005, 09:12 PM   #70
steenoe's Avatar
Tortello, I am amazed allready by this amp If you have some improvements, up your sleeve, that would be even greater Now that I started etching my own boards, I will jump right in, for sure If you post those nice pdf's again
Steen
New Aleph-X PCB group order... hifiZen Pass Labs 334 19th November 2007 08:45 AM
IRFP044 Group Order PrimeCase Pass Labs 94 6th May 2004 07:34 PM
Aleph PCB group order Tieftoener Pass Labs 84 11th November 2003 07:31 PM
Copyright 1999-2017 diyAudio
