| Group Buys Members group buys |
#21 |
Just got mine today, it took 6-7 weeks.
I agree with Lucas_G, the boards are very well made. Thanks Digi01! |
#22 |
I get on to the surface shipping so slow,but it is cheap and so safe.if we use fast air post,it may take 1~2weeks to arrive.the cost is 10USD for 2PCB boards shipping.
BTW:a Hongkong diyer have finished the boards,and send me some pic show his workshop. cheers -digi |
#23 |
Hi digi01,
Arrived on the 28th. Nice boards! Everything arrived intact. Thanks for your efforts. Best regards Paul
A poor life this if, full of care We have no time to stand and stare. |
#24 |
congratulations
hearty cheers -digi |
#25 |
Digi,
Is there any change that you will do another round of your boards/kits. I missed this round and as everybody is so possitive about your work I would like to buy (and build) them very much. I would order 4 kits, Leo |
#26 |
Hi digi-
I would also like to order a set if you offer this kit again. Thanks in advance, Troy |
#27 |
Just name the time and place...
Guiness |
#28 |
thank you for your appreciation
lately,I have received some e-mails ask for my boards.I may do another round orders.dual mono zen headamp boards,total=60 PCBs (30 sets) R/C kit,total=10 sets (maybe add,basis on order quantitys) if you have other ideas,please add comment. btw:I am considering append power supply caps and bridge diodes in R/C kits.I have find some good components. such as ELNA standard or Nippon chemi-com 6800u50v caps. pic view: |
#29 |
The boards is available now.
dual-mono PCB boards, Total = 60 pieces(30 sets) The price is $3.6 USD per board.building one amp need 2PCBs boards($7.2).the boards including partlist. surface shipping costs is $5 USD.take 2-6 weeks arrive. by air ,cost is $10 USD.2 weeks arrive. R/C kit,total = 10 sets. each kit can fit 2 dual-mono boards and mono power supply used. part list- main boards: standard film resistors, R1\R2\R3\R8=1K,1/4W R4=20K R5\R6=220 ohm,1/4W R7=33K,1/4W R9=220K*,1/4W R13=100K*,1/4W R14=180K*,1/4W R15=470 ohm,1/4W dale resistors, R10\R11\R12=1 ohm,1W R18=5.6 ohm ,3W C1\C3=100uf/35V ,ELNA CERAFINE C2=4.7u100vBP (For audio) C4\C5=1000uf/63v ,ELNA FOR AUDIO C6=2200uf/50v , ELNA Standard Audio Grade socket,2 pins output/psu small socket,input power supply partlist,(for dual-mono building) ELNA standard 6800u50v cap*4 1n4001 diode*8 25x40 holes bread board*2 pre R/C kit,the total cost is $40 USD. surface shipping cost is $5. by air it is $15. you need to email me directly to place an order. My e-mail : vcgft@yahoo dot com dot cn |
#30 |
Digi01,
As you know, I built a Zen headamp recently using perfboard and point to point wiring, but I was well into building it when you made the pcb/kit offering, so I decided against buying some of your boards. I have had my amp completed for a few months now, and I have been slowly tweaking it into better performance, including following a couple of your suggestions. This circuit definitely benefits from some carefully considered tweaks. Of course, now I can't help but wonder how much benefit is achieved by using a good pcb instead of perfboard, and now that you are offereing pcb's again it has become a factor my curiosity won't let me ignore. You mentioned to me once that my amp circuit looked similar to the first version you built. So ... does the circuit on a PCB sound significantly better than with point to point wiring? For the record, the changes that I found made the biggest difference in sound quality: 1) Replace the potentiometers with fixed value resistors once you know what exact values you want. 2) Add a film bypass cap to the output electrolytics. 3) A separate P/S voltage regulator circuit for each channel made a whopping difference. 4) More bias (I'm running mine at 0.3A) If you think the PCB's will make a noticeable difference, then sign me up for a set. Looking forward to your thoughts. |
| New Aleph-X PCB group order... | hifiZen | Pass Labs | 334 | 19th November 2007 08:45 AM |
| IRFP044 Group Order | PrimeCase | Pass Labs | 94 | 6th May 2004 07:34 PM |
| Aleph PCB group order | Tieftoener | Pass Labs | 84 | 11th November 2003 07:31 PM |
| Page generated in 0.12981 seconds (85.06% PHP - 14.94% MySQL) with 11 queries |
