"The Wiener" TPA3118 amplifier, group buy #3 + "Wiener Pro" prototypes. - Page 3 - diyAudio
Go Back   Home > Forums > Commercial Sector > Group Buys
Group Buys Members group buys
Old 11th April 2016, 05:37 AM   #21
TNT is offline TNT  Sweden
Originally Posted by gmarsh View Post
The Pro is a stereo card this time around.
Given enough interest, and after the stereo Pro design is built and tested, I'll make a PBTL version of it.
Ok I'll check the development a bit more...
Old 11th April 2016, 05:38 AM   #22
Anyway, getting the order/interest list going. Quote the most recent post and add your name to it if you want something.
loafimus: 4 x bare PBTL PCB + 4 x microcontroller
ChuckT: fully assembled stereo Wiener + fully assembled Pro
DawgNo1: 2x stereo 3118 fully built.
jonners: 1x stereo fully assembled Pro
Old 11th April 2016, 02:16 PM   #23
gmarsh is offline gmarsh  Canada
gmarsh's Avatar
Got a PBTL version half done last night. Wondering what I'm gonna do now with the extra board space gained from ripping out one of the inputs...
I'll keep everyone posted.
Old 13th April 2016, 11:38 AM   #24
Pyjamas Before Chris: 1x stereo fully assembled Pro
Old 13th April 2016, 12:31 PM   #25
Hi, I am arranging a group buy in my area and I have 12 assembled tpa3118 and 3 Pro assembled so far. I will confirm the details later.
If we don't order the filter kit, we can specify the load impedance put on the board, is that correct?
Old 13th April 2016, 04:38 PM   #26
adn6244 is offline adn6244  Singapore
May i know what is the output power into 8 ohm for both the pbtl and stereo amp?
Also can it be powered by the $20+ abletec smps ?
Thanks.
Old 13th April 2016, 05:25 PM   #27
gmarsh's Avatar
Nice... that's a big order. Mind the comment in the first post though, the Wiener Pro is an experimental prototype and there's a chance the first crack at the hardware won't work I guarantee you'll get a working board if you pay for one, but there might be delays.
Generally I install the provided load impedance (4/6/8/whatever) on a fully built board when I build and test it. And if you order a filter kit, I include the other inductors/capacitors that are needed need to change it to any of the other load impedances.
In theory I could test the card, desolder the output filter and let the end user stuff in the parts that they choose...
Old 13th April 2016, 08:13 PM   #28
gmarsh's Avatar
Thanks.
Output power depends on the power supply voltage.
12V supply: 30W peak/15W RMS sine into a 4 ohm load. 15W/7.5W into 8 ohms.
24V supply: 120W peak/60W RMS into 4 ohms, 60W/30W into 8 ohms.
Got a link to the Abletec supply?
Old 14th April 2016, 12:54 AM   #29
Abletec Smps
Guess it won't as the smps has 53v, need a step down to get 24v. 60w with 24v psu is good enough though.
Thanks for the info.
Old 14th April 2016, 01:34 AM   #30
is it possible to order a board with 16 ohm output impedence? or the filter kit already have component to built 19 ohm myself?
"The Wiener" TPA3118 amplifier card gmarsh Group Buys 812 17th May 2017 08:33 AM
Wiener group buy #2 - Stereo and PBTL editions available! gmarsh Group Buys 259 18th March 2017 04:28 PM
Adding "home style" I/O to a "Pro" Amp Soldermizer Class D 2 13th March 2012 03:17 AM
Wanted to Buy: Pairs of 5-1/2";6-1/2";8";10" Seas Aluminum Woofers dtm1962 Swap Meet 0 15th January 2010 04:38 PM
What makes an amplifier "bright", "warm", or "neutral"? JohnS Solid State 51 13th December 2009 06:42 PM
Copyright 1999-2017 diyAudio
