Group Buys Members group buys
Maya R2R Advanced Volume controller
Old 28th April 2017, 09:44 AM   #341
danzup is offline danzup  Romania
danzup's Avatar
Originally Posted by pixelpusher View Post
Nope, nothing comes up. The board is fully seated. I've been using the controller for some time with the bluetooth board off since I previously did not have an android device. Could that have caused a problem?
My phone is a Moto G5. I also tried several i devices as well as a Macbook. Nothing sees the Maya bluetooth.
My phone is a Moto Nexus 6 and after upgrade to Android 7.1 (last Android version) sometime when i go "Bluetooth --> Advance --> scan for Bluetooth device " it find the device (Maya) but crashing .Google did not get it right this upgrade....
I do nothing and then Bluetooth stack reinitialize and work OK.
After that i am starting our Android application then select the new paired Bluetooth device and work like a charm.
But my tablet with Android 4.0 work always without issue on Bluetooth !!!!
Please do a double connect disconnect of power for Maya after inserting module Bluetooth.
Please do scan again Bluetooth .
Do you see a "Serial Adaptor " when you scan nearby Bluetooth device on your phone ?
There are not better tube than 6P3S and 6N2P for my ears !
Old 28th April 2017, 04:39 PM   #342
pixelpusher is offline pixelpusher  United States
I've tried a number of things; several bluetooth finding apps and an old android phone. Nothing will see the Maya. It really doesn't matter much to me anyway. I've got a Harmony remote that works well.
Old 28th April 2017, 04:41 PM   #343
Originally Posted by danzup View Post
On public demand here is the testing version of software for MAYA with OLED display that turn off display after 1 minute of inactivity .
Wow, that was fast! Thanks danzup
Old 14th August 2017, 02:04 PM   #344
NATDBERG is offline NATDBERG  United Kingdom
It's a longish thread and a little while since I've been thinking about actually installing my Maya for BPBBP.. so forgive me if this has already been answered.
For a smoother feel, should it be needed, for the rotary encoder, I was thinking of getting a Bourns encoder in the future (as used in my Audio Synthesis DAX Decade - very nice feel). What specs would I need to replace the one that comes with the Maya? 64 pulse? what else?
I would also like to use a rotary control for select, continuous turning of a knob to replicate continuous pressing of the select button. Has anyone done this and how would one go about it? Is there a select downwards/backwards option? Maybe the maya control counts the momentary select switch as a pulse and so a simple incremental encoder is all that is needed, perhaps even the same as the one supplied?
Old 1st November 2017, 08:54 AM   #345
tvicol is offline tvicol  Romania
tvicol's Avatar
Maya R2R Advanced Volume controller Maya R2R Advanced Volume controller
A new Maya firmware update is available from http://vicol-audio.com/img/maya/maya..._rays_oled.zip
This update add a new menu option for screen-saver, prepare unit for IOS BLE module support and correct several bugs.
Update procedure is documented here http://vicol-audio.com/img/maya/Maya...re_upgrade.pdf
Brgds,
Tibi
Vicol Audio
Old 1st November 2017, 10:12 AM   #346
burkm is offline burkm
Does this work also for the BPBP version ?
Old 1st November 2017, 10:22 AM   #347
tvicol's Avatar
Originally Posted by burkm View Post
Does this work also for the BBP version ?
Only with Maya.
For BPBP a new firmware will follow.
Also I'm preparing BPBP with IOS support for 1st December 24h sale.
Brgds,
Tibi
Vicol Audio
Old 23rd November 2017, 10:36 AM   #348
tvicol's Avatar
Soon on IOS App Store.
Maya with BLE will be available starting with 1st December.
Maya for BPBP with BLE will be available on 1st December as well.
Tibi
Vicol Audio
Old 29th November 2017, 03:04 PM   #349
motorica is offline motorica
Any release notes for new firmware ?
instruction for applying new firmware ?
Thanks !
Old 29th November 2017, 03:49 PM   #350
tvicol's Avatar
Thanks !
Please check my website vicol audio : MAYA - world best stepped volume attenuator
http://www.vicol-audio.ro/img/maya/M...re_upgrade.pdf
Brgds
Tibi
Vicol Audio
Maya R2R Advanced Volume controllerHide this!Advertise here!
Interest check on Vicol Audio Maya R2R Volume controller aradan Group Buys 221 5th November 2017 06:34 AM
R2R Shunt Volume with 3 selectable sources quanghao Quanghao Audio Design 13 2nd August 2016 04:30 PM
Vicol Audio R2R Volume controller Builds aradan Analog Line Level 13 18th April 2016 02:06 PM
R2R/Shunt volume controller; Quasar amplifier; Silver-Gold interconnect tvicol Vendor's Bazaar 3 27th June 2011 06:40 AM
Samsung 1602VFD For CDROM Controller & Remote Volume Controller slowgay Swap Meet 2 22nd November 2008 02:44 PM
