Group Buys Members group buys
GB Pass M2 Clone Boards with 120mm UMS spacing by Tea-Bag
Old 30th May 2018, 01:22 PM   #351
Tea-Bag is offline Tea-Bag  United States
not politcally affiliated
Tea-Bag's Avatar
Originally Posted by nano35 View Post
Just a quick update for my build:
I keep forgetting to order the right amount or always missed some parts. Thus...no testing yet.
I reused my humongous 10uF red Wima from the other project. (almost as big as the Edcor transformer)
I am tempted to try Gold/silver oil for 0.1uF and 1uF bypass caps after listening to my friend's Whammy headphone amp which was equipped with 2 expensive Gold/Silver oil caps.
That really shocked me: extreme clarity, 3D feel, romantically beautiful; only that the bass is a bit too much for my age.
The boards are very nice; my solder gun might be too hot and made some brownish burn marks around.
That's it! more to come later.
I don't want to discourage anyone from tweaking. It took me some tweaking to come up with the recommended components I listed.
I did not find changing the input caps around in the M2 to alter the sound too much. I am not certain why. I assume the Edcor dominates the signature sound. Changing the Mosfets was big, signal resistors a little. The Wima bypass I used over the Elna 10uf may have brought a little more air to it. It may be that the Elna and Edcor are both a little lush, so kind of adds to the smoothness, but may harm resolution ??
I know this. Because of hot weather, I took the M2 out of office system (which I use a yamaha 9.1 receiver on currently.) and went to use the speaker outputs off the Yamaha....Such a loss of sound quality, its sterile tone deaf and generally uninvolving. It does however keep the M2 from overheating my office space when it is 30c outside.
Salas Boards 2018#1 On Order | Hot-Rod DCB1 boards and kits In Stock, PM | M2C Boards, PS and transformers Available PM | Sony VFET CSX2 AL boards In Stock
Old 30th May 2018, 03:40 PM   #352
dewdrop is offline dewdrop  Singapore
Thanks for helping us save money! It is good that you have tried so that we won't have to. ;-)
What about opting for the Audio Note tantalum resistors? Will that make a positive impact?
Can't wait to build mine.
Ed
Old 5th June 2018, 10:52 PM   #353
BRN is offline BRN  United States
I’m going to use a DIYA power supply that I have with this amp. I want to know if I can use an AnTek 400VA 20V transformer and want to know if I can use it or do I need an 18V transformer?
Old 5th June 2018, 11:11 PM   #354
Mark Johnson is offline Mark Johnson  United States
Mark Johnson's Avatar
Eleven percent greater supply voltage means eleven percent greater power dissipation(*) that the heatsinks must radiate into the air. Do you plan to increase the heatsink area by eleven percent?
(*) since the optocoupler bias circuit used in the M2, guarantees the amplifier's DC bias current remains rock solid and constant. Voltage rises 11% but current remains the same --> power dissipation rises 11%
Old 6th June 2018, 12:29 AM   #355
I was going to use the Dissipante 4U 300mm chassis, but it sound like I would need the 5U. I don’t want to go deeper.
Old 6th June 2018, 12:46 AM   #356
6L6 is offline 6L6  United States
6L6's Avatar
The 4U 300 will be fine with 11% more heat than the standard voltage.
Old 6th June 2018, 01:58 AM   #357
Mark, 6L6,
Thank you. That sounds great.
Brad
GB Pass M2 Clone Boards with 120mm UMS spacing by Tea-BagHide this!Advertise here!
GB Pass SONY VFET Version 2 - AL Boards by Tea-Bag Tea-Bag Group Buys 112 22nd May 2018 01:38 AM
Tea Bag PSU flocchini Swap Meet 5 9th November 2015 01:04 AM
Pass M2 Clone buzzforb Swap Meet 1 7th November 2015 08:57 AM
FS: 2x F5T and 2x PS Boards Tea-Bag Version camshaft Swap Meet 3 22nd April 2013 04:21 PM
WTB URGENT Tea-bag's F5T PSU boards Nikitas Swap Meet 0 9th December 2012 05:14 PM
