HQ-IV tube output balance DAC
Ok, thanks, one more question. The output cap C2,C5, you have 1uf/400v, will there be a big difference if I use a 0.47uf/630v instead. I have those on hand already.
Adeveza, this is the DC blocking cap. To customise the exact value to your system you need to know the input impedance of the next load in the system.
Coupling Capacitor Calculator by V-Cap.
Either have the blocking cap at the source or the amp, if you have one on your amps input, then you could leave the cap off the I/V board, less caps the better. When you build the I/V, check the DC on RCA output with and without C2,C5 cap.
I built my amp, I dont have a coupling input cap in there. I have a 100 ohm grid resister, and a 100k reference to ground. I could say I have 100k input impedance on my amp.
Thanks for that link BTW, it looks like I may have to use a 1uf to get the best response.
OK Quanghau, I guess some things we will figure out ourselves.
I will use a cap for c2 as this will cause no harm and I will scope the output any way to see. On Your previous prototype 'green' pcb's this cap is in place an you say it works very well and now there is no rational reason to leave this huge area unpopulated. The board could have been smaller if this part is unnecessary.
Adevaeza - I too have both LT1084 and LT1764 ready but also considered using 1084 simply as I did not need the ultra low drop out, it can handle more current and as you say - it's cheaper.
There appears no reason not to use LT1084 unless we get a definitive explanation. The pins are correct for use and as long as you have one volt for the drop out then you should be good to go. 12VAC in will give you over 16VDC out which is plenty.
I also have a query regarding the H1 & H2 +70V jumper points on the HV supply board if anybody can figure them out.
Don't know why some parts are omitted in the HV PSU (I guess the 2SK170 did not live too long) and why LT1084 can not be used in the LV PSU. I received my boards only a few days ago and I am building the LV part to check if it works OK with NOS tube transformers with their standard 6.3V windings.
You will likely need LT1764 when using 6.3 V windings and 6.3V filaments. The fact that LT1084 is cheaper is eh...a non issue considering the total cost and the probable need when 6.3V windings are the only thing you have got. LT1084 won't cause an issue with 12V windings as far as I can tell but maybe Quanghau can elaborate ?!
Do you mean that the GND of the filaments is lifted by 70V ? Will check the board later when I am home again.
Thank you JP. I wondered if it was a resistor divider on the B+ and if the heater GND terminal on the outer edge should be connected to star ground. These are to eliminate hum if any?
no hum
1. you can connect GND of filament to GND of HV. it is no hum.
2. or you can connect GND filament to +70V, it is no hum.
all the sample , some tube may be you can use 2.
thanks
