Group Buys Members group buys
"The Wiener" TPA3118 amplifier card
Old 5th August 2017, 03:26 AM   #831
paugie is offline paugie  Philippines
Originally Posted by bk856er View Post
For the standard Wiener I had a strong preference for a linear regulated supply over laptop bricks and even audio-grade SMPS. Even a very basic linear regulated supply was better,
So I would say YES try a linear regulated supply!
BK
Thanks much, BK
Old 13th August 2017, 06:13 AM   #832
anomalous is offline anomalous  Australia
Default is the Weiner a dead project?
I've been asking every now and then for a bit over a year now - is there going to be another round of Weiners produced. Seems like the answer is looking like a no.
with that in mind, anyone have a weiner pro they'd like to on sell?
cheers
ben
Old 15th August 2017, 04:52 AM   #833
jorem is offline jorem  United States
BK was kind enough to offer a spare board which I was able to wire up to my build. I quickly reviewed the switch settings and it looked good, made sure not to tighten screws too much, and it made noise when I hit play, so I put it away for later.
When I got it out again, the speakers started to periodically "get sucked in" for half a second. It would still amplify the source for half a second between each thud. I took it out and tried different settings and found that 1SPW mode would work but not BD mode. After I put everything back together I noticed 1SPW sounded different, like the low end was very attenuated. There was also noticeably more signal noise with no input plugged in. This led me to take it out of the case again to try different settings.
BD mode would produce a periodic fault/speaker thud. The speaker thud was initially a long DC signal as the driver would travel pretty far down and stay down for half a second. I measured it at the time and was getting just over 12VDC, which is the battery voltage it was powered by.
I left it to troubleshoot another day. I unwired all the terminals and took it completely off the case. At this point both 1SPW and BD mode were both producing the periodic fault, but the thud changed to a pop at some point. The start-up delay adjustment directly impacts the length of the period between each fault. The LED turns off at the same time as the pop.
When I read the voltage during the faults now, its about 0.3VDC. If I decrease the start-up delay it will climb to 1.7VDC. I suspect my DMM isn't sampling fast enough to catch the faster spike unless I increase its frequency.
With no inputs connected, a 19V laptop brick, and two speakers attached, I tried pretty much all of the DIP switch settings. Placing the board into standby mode between each change.
Two of the states I tried did produce a slightly different result - the pops we're a split second apart from one another. All other states had both speakers pop at about the same time. This happened in these states:
1SPW 1 Mhz and 26dB pop separated by ~1/4 second
1SPW 1.2 Mhz and 26dB pop separated by ~1/3 second
I'm not sure what to do now, I guess I will take another good long look at it to see if I missed anything I may have damaged. Thank you to BK for helping me get this far.
Photos/Videos - Shared album - Josh Remaley - Google Photos
Old 17th August 2017, 02:55 AM   #834
bk856er is offline bk856er  United States
bk856er's Avatar
jorem and I took the troubleshooting as far as my (limited!) knowledge could go.
Ideally gmarsh or another TPA311x guru can suggest informative test points/diagnostics.
I'm hopeful we can identify the fault in jorem's replacement board and repair it. The other lingering question is the root cause of the failure(s). jorem's project is super cool and it'd be great to see it alive again!
BK
Old 1st January 2018, 07:45 PM   #835
vanofmonks is offline vanofmonks  United States
Is there a BOM anywhere? The project at mouser doesn't have an part numbering. I purchased a while ago and finally getting around to build and it would be great to have a bom.
Old 1st January 2018, 08:28 PM   #836
bk856er's Avatar
gmarsh made a nice pdf with all info. If you can't find it pm me your email and I'll send it to you.
BK
Old 4th June 2018, 10:48 PM   #837
hallcon83 is offline hallcon83  United States
hallcon83's Avatar
is there any chance of generating another Group Buy? I would really like to have a chance to build this amplifier.
Old 5th June 2018, 05:48 AM   #838
cipriano is offline cipriano  United States
Yes please, another group buy. I'll buy two to show my support!
Old 10th June 2018, 07:39 PM   #839
matt_garman is offline matt_garman  United States
I have a version 1 Wiener stereo board that is collecting dust, see build here. I've since robbed the power supply for another project, but everything else remains.
PM me if interested.
Old 12th June 2018, 10:53 PM   #840
sztabo85 is offline sztabo85  United States
nuts.. just found this post, after ordering (ebay.de) 6@ Sanwu TPA3118s...
For 6-way (stereo, 3-way) active speaker system;
The heart of which will be Wroclaw Audio Force Najda v1.3
Any possibility of finding/ordering? 2@ of these units... with mod for 4ohm mids.
Or, could ask seller if they are aware of this mod.
Also, best guess for total current draw @ 18VDC? (tweets 8 ohm, Mid 4 ohm, woof 8 ohm).. possibly mounted in 1/2U rack case.
Also, considering trying Peltiers on the bottom for cooling.
thanks for tips,
John
"The Wiener" TPA3118 amplifier cardHide this!Advertise here!
Joe Rasmussen "Trans-Amp" - 40 Watt Transconductance "Current Amplifier" Joe Rasmussen Chip Amps 391 12th August 2018 08:24 AM
FS 5" Sub / Sub Plate / TPA3118 Amp ezas Swap Meet 0 6th December 2014 07:10 AM
"WTB" "The Wire AMP" Class A/AB Power Amplifier based on the LME49830 with Lateral enantra Swap Meet 3 23rd December 2012 06:36 PM
"sound card" vs external DACs FastEddy Digital Line Level 23 4th October 2010 05:22 PM
What makes an amplifier "bright", "warm", or "neutral"? JohnS Solid State 51 13th December 2009 06:42 PM
