Group Buys Members group buys
GB for TPA3116/8 PBTL bare pcb
Old 24th August 2014, 04:54 PM   #191
DUG is offline DUG  Canada
Originally Posted by irribeo View Post
Dug what is the little + middle of pcb between chip and inductors? Was looking at that soldering all little smd's and forgot to ask earlier, it isn't speaker or trace polarity, you left a design-cursor there?
It is actually one of the polarity symbols for the large power supply caps...just not in the correct place.
Doug We are all learning...we can all help
"You can't stop the signal, Mal. Everything goes somewhere..."
Old 28th August 2014, 09:56 AM   #192
rafalkac is offline rafalkac  Poland
Hi, can I use R11-20k resistor instead of 10k? I forgot to order it and only this part is blocking me to finish boards.
Old 28th August 2014, 10:32 AM   #193
irribeo is offline irribeo  Netherlands
That is only for mute upon startup isn't it? Btw 2 stacked would be 10k
Old 29th August 2014, 04:56 AM   #194
ChrisMmm is offline ChrisMmm  New Zealand
ChrisMmm's Avatar
Default Power supply for dual mono
I have been using 120va toroid (2 @ 15v windings 4A each) for single stereo TPA3116 boards and this has worked well. I get 21v at the amp.
Using 2 of Doug's boards making a stereo pair do you think the power demand goes up to any degree? I mean at the speaker it would still be the same demand per channel even tho 2 chips now supply the power. My thinking is this is still an adequate transformer but would appreciate some opinions.
Old 29th August 2014, 03:16 PM   #195
A single 5A or 6A 12V brick seems enough for stereo board, it is insufficient for my PBTL's, bass output gets limited, but maybe that's load???????
Old 1st September 2014, 07:05 PM   #196
afoor, randytsuch, col_s, ChrisMmm
Your boards (and ic's) were mailed out on Friday.
I am almost finished the test bed and then can get out some others that are waiting for testing.
Doug
Old 1st September 2014, 08:07 PM   #197
ChrisMmm's Avatar
Doug
Awesome many thanks Doug.
Old 9th September 2014, 07:04 AM   #198
undefinedza is offline undefinedza  Europe
Hi there Doug,
Is it too late to get two boards with soldered TPA chips?
Thanks,
Chris
Old 9th September 2014, 11:15 AM   #199
Originally Posted by undefinedza View Post
Hi there Doug,
Thanks,
Chris
Not too late.
I am slowly clearing orders so it might be a little while (a few weeks) before I get to you.
If you can wait I will put you on the list.
Did you want the boards separate or joined at the ground plane? ( labeled as 1 pair)
Doug
Old 9th September 2014, 11:22 AM   #200
Awesome!
I'll take one joined ground plane pair, with soldered ICs + a kit for each.
I believe that's $94CDN excluding shipping. In a few weeks I'll be back in London.
Could you point me towards a post with the parts list in the kit?
Thanks Doug!
GB for TPA3116/8 PBTL bare pcbHide this!Advertise here!
GB for Leach Low-TIM with 8 + 8 BJT outputs (bare PCB) linuxguru Group Buys 55 16th June 2018 08:19 AM
SPID/F input bare pcb ? Eldam Digital Line Level 8 4th January 2014 01:21 PM
Bare PCB's littlerick Parts 8 17th March 2010 01:11 AM
Lite DAC 38 PCM1704 bare PCB's Alfetta87 Swap Meet 2 19th April 2009 05:48 PM
