Group Buys Members group buys
Calvin Buffer for Paradise
Old 5th November 2013, 09:43 AM   #371
Werner Hammelmann is offline Werner Hammelmann  Germany
Default Trannies for Calvin GB update
Hi folks
All the trannies are on the way now
Before you start with the boards please read "Alfreds" new Link-list
(Calvin buffer assembly guide) and "Calvins" clarifications. Well done!!!!!!
I had a fault on my boards as well. But now is all clear.
Happy days
Werner
Old 5th November 2013, 04:20 PM   #372
hesener is offline hesener  Germany
Originally Posted by hesener View Post
Interesting.... thanks for all that work and sharing your results, obviously it pays off to check twice! I should measure mine as well then again (yes I admit my lazyness, after assembly I was so eager to listen that I didnt re-measure ) and now my Paradise is with a friend......
Anyway, the assembly guides have been updated, fixing some BOM issues and I also added a stuffing diagram with the component designators, access through the link list in my signature.
.... and there was another bug.... should be fixed now (thanks a lot Werner!!!) The link remains the same.
Paradise documents are here: Link list
Old 8th November 2013, 03:02 PM   #373
atupi is offline atupi  Romania
Anyone can tell me if pcb's has been shipped ?
Thanks,
Adrian
Old 8th November 2013, 04:27 PM   #374
look here Calvin Buffer for Paradise
Old 8th November 2013, 04:52 PM   #375
Well..... should be arrived until now. I can understand it is lost ?
Old 9th November 2013, 08:57 AM   #376
Give it one more week or so, no pun intended but Bucharest is farther away than San Francisco, in a postal way..... Please PM me if they don't show up until end of next week ok?
Old 9th November 2013, 09:19 AM   #377
Sure, no problem. Usually i receive parcels from Germany and other EU countries in about one week and from USA in about 10 days.
Let's see if it will appear in my mailbox after all.
Old 10th November 2013, 04:49 PM   #378
kumori is offline kumori  Europe
Originally Posted by Bksabath View Post
Alfred culd you please post a guide for very dumb peoples (like me) on matching the Jfets
Tanks
I also have a little trouble with matching here.
I determined Vp of the 2SK170 and PN4391 I used with this method. Apparently it is a little bit coarse, but I assumed I only needed to get good relative values.
Vp of the SK170 was in the range of -0.63 V to -0.64 V, IDSS around 9-9.5 mA
Vp of the PN4391 was around -6.5 V
Still I get a relatively large DC offset at the output of around 350 mV on one channel and 450 mV on the other. The 2k trimpot only can adjust it within about +-50mV, so I canīt set it to zero.
Despite proper matching within the 2SKs and PN-transistors, do they have to fit to each other? So do I need a specific 2SK170 Vp (or IDSS) range together with the right PN4391 Vp-range ? The built manual states around 8-8.5 mA IDSS for the 2SK170 so Iīm a little higher here. Is this ok?
Or is it crucial to set up Andrews measurement setup from post 368?
Old 12th November 2013, 09:23 AM   #379
voxxonline is offline voxxonline  United Kingdom
voxxonline's Avatar
Gents. Is there any spare boards left ? I d like to ask one board for my stand alone buffer.
How to find time to finish my projects ?
Old 13th November 2013, 05:11 AM   #380
Catal is offline Catal  Italy
Boards arrived,
thanks Alfred.
Frank
Calvin Buffer for ParadiseHide this!Advertise here!
Paradise Builders Joachim Gerhard Analogue Source 4127 19th February 2018 05:42 PM
MY PARADISE Bksabath Analogue Source 61 21st March 2013 10:59 AM
Diy Paradise! alexmoose Tubes / Valves 3 24th July 2006 04:37 AM
Ping Calvin moray james Planars & Exotics 7 20th September 2005 10:03 PM
Another way to paradise ? Bernhard Pass Labs 3 8th August 2003 10:19 PM
