Group Buys Members group buys
Old 5th November 2013, 06:41 PM   #151
still4given is offline still4given  United States
still4given's Avatar
Hi Earthquake.
You are right, there is a lot to read through. Ranchu32 started a new thread to try and gather the info in a smaller thread but even that is getting long. You can find it here.
I put together a parts list by modifying Byron's list based on the latest schematic I could find. You can find it there. I know that I had to make some changes once I got the amp built and I am looking over the BOM this morning to see if the changes are in there. I will report back once I have had a chance to finish. I will try to get the schematic, BOM and the board top-view with part numbers gathered up and posted together here and in that other thread too.
Blessings, Terry
Old 6th November 2013, 09:54 AM   #152
Earthquake is offline Earthquake  United Kingdom
Thanks Terry your a star.
Old 12th December 2013, 10:37 AM   #153
destroyer X is offline destroyer X  Brazil
destroyer X's Avatar
Default Blameless concept...the amplifier i have used as reference
First time i build it i found it sterile ... without taste if it was a food...without salt if it was a steak....then i have tweaked as Self said the amplifier was only a "frame"... a "skeleton"... an idea of low distortion that should be researched.... a concept!
If he said this or not i am not sure...this is what i understood..then i started to work hard on it.
I made all i could using the instruments i had, scope, simulator and my ears and i found it the best amplifier i have ever listened too ... and i have assembled thousands ... within these thousands several different topologies ... i found it the best and i have ever followed this inspiration.
It is almost the same..also it is not the same ... does not sound the same..but it is hardly inspired ... the "frame" was copied for sure.
You all can see the differences ... compare the sound and the schematic and you gonna see all the hard work i have made.
There's no bootstrap in Blameless amplifier...this is the first difference you can see....and several other details that sounds good ... assemble one and other and come here to say the differences .... i would love to hear that.
Why dots? when i write i use to put dots in place of comma .... i was a Radio Amateur by 30 years long.
Blame MKIII-HXHide this!Advertise here!
Dx Blame MKIII-Hx - Builder's thread destroyer X Solid State 2184 8th January 2018 08:00 AM
group buy for DX Blame MKIII Hx PCBs ByronInPortland Group Buys 252 13th May 2016 04:14 AM
Dx Blame MKIII Supercharged will soon be released destroyer X Solid State 346 22nd April 2014 03:01 PM
Tips for a New MKIII Hx build ibuildstuff4u Solid State 3 22nd May 2013 04:14 AM
Group By: DX Blame MKIII Hx boards ByronInPortland Group Buys 9 19th July 2011 07:21 AM
