"Subbu DAC V3 - ES9023/WM8804 SPDIF & Power Supply PCB" Group Buy
Count me in for a soldering service also if one become available. Thanks Korben.
PJN
Hi PJN
Yes it's on the way, waiting for some informations before publishing.
I'll use a similar "Form" as the one used by Subbu for registering & Paypal.
You'll receive then a fully soldered, functional & tested DAC/PSU.
I hope it will be soon, same thing for the Parts GB ;)
Phil
Ive paid as well.
anyone know of a cheapish pcb kit with smd components that i can purchase and do some practice on? ideally something that does anything of use, but i can go for something scrappy too. thanks!
Hi parb
You could try desoldering/soldering exercices using broken/faulty computer motherboards or others electronic devices SMD populated ;)
Keep your money to buy SMD solder paste, magnifying glass and solder braid :cool:
Phil
I have a pretty good soldering iron that my brother gave me (his company was upgrading their equipment), and i was in the market for a heatgun... so i found this one and at the price i figured, what the heck. maybe a bit of an impulse buy but if just the suction for the fumes work i'm happy... 4 IN 1 "X-TRONIC" MODEL #9020-XTS HOT AIR REWORK & SOLDERING IRON STATION, FUME EXTRACTOR & VACUUM PICKUP TOOL - 5 Hot Air Nozzles - 10 Asst. Solder Tips - 1 Extra Hot Air & Soldering Iron Heating Element - Pinpoint Tweezers - 1 5X MAGNIFYING LAMP!!!
I bought something similar to this and it blew like a hair dryer... I couldnt do any smd soldering with it without the parts bowing all over the place. It went back the same day I got it. I eventually got a hot air solder pencil, I've used a good soldering iron with a very fine tip.. but I like toys.
Hi parb
Phil
Yep, that's what I've been doing.
Used a cheap hot air gun (the paint stripping type) to remove components from a couple of dead boards I salvaged from junk.
Cleaned up the pads with a bit of braid.
Then put the components back on again.
So far, I've done down to 0603 passives and a ~88 pin quad flat pack.
All seem to have been successful, at least nothing melted or lifted, and no shorts under a magnifier.
Of course, the boards are still dead, so who really knows :D
I can highly recommend the link in post #93
Dave waffles on a bit, but he sure knows his stuff.
Mark
