Group Buys Members group buys
"Subbu DAC V3 - ES9023/WM8804 SPDIF & Power Supply PCB" Group Buy
Old 5th November 2013, 08:39 PM   #561
atupi is offline atupi  Romania
Default Let the party starting ...
Finished one power supply giving steady 4.98V
I like that smd pads are confortable size. Soldered one Wm8804 without problems.
Old 5th November 2013, 08:57 PM   #562
cristi289 is offline cristi289  Romania
cristi289's Avatar
Send a message via Yahoo to cristi289
Very nice, Adrian! You do a great job. Call me when they are ready...
Cristi.
Old 5th November 2013, 09:21 PM   #563
freeman is offline freeman  United States
Default grounding scheme for dac
This is a question for anyone: Should there be ground between chassis and the psu or dac boards? Thanks all. Looking forward to starting my build. -freeman
Old 6th November 2013, 02:20 AM   #564
tofurky is offline tofurky  United States
still waiting here on the east coast also, should i be concerned?
Old 6th November 2013, 02:46 AM   #565
fredlock is offline fredlock  United States
I think we should be more concern since we are in California and live close to Subbu.
Old 6th November 2013, 02:58 PM   #566
Skiivari is offline Skiivari  Finland
Could someone please send me the bom, or just tell me what type of transformer to get, what are the needed specs. I didn't get the bom since I registered for the gb later than everybody else and I could check if my local shop has the right kind of transformer. The other parts i'll get from the parts gb
Old 6th November 2013, 03:02 PM   #567
wirewiggler is offline wirewiggler  United States
Subbu responded to a message from me, he explained he sent them out in batches. He mentioned in an earlier post he has been busy with work traveling. I can relate.
Bill
Old 6th November 2013, 03:05 PM   #568
Ryssen is offline Ryssen  Sweden
Ryssen's Avatar
I haven´t got the boards in Sweden either,but I´m sure they will come.....(I hope)...
Regards Åke
Old 6th November 2013, 03:17 PM   #569
I see on the schematic Q1,Q2 and Q3 (Q2 and Q3 seems paralleled). I believe this is an error and there is no Q3.
What is the secret of soldering Q2 as the case covers entire soldering pads and there is no acces with soldering iron ?
Old 6th November 2013, 05:38 PM   #570
passive420 is offline passive420  United Kingdom
they are difficult but do-able, at the very sides of the Q2 package you should see exposed contacts that run under the xo.
tin the pads and align the xo over them with flux and apply heat to one exposed contact by pressing the flat of the bit firmly against the side for a second or so. Check it has taken and the alignment and continue with the rest. Careful with overheating.
You can check continuity by C17 and L3 pads to the very side of the xo contacts - only two of the xo contact pads are used, is this correct?
Hope that's clear
"Subbu DAC V3 - ES9023/WM8804 SPDIF & Power Supply PCB" Group BuyHide this!Advertise here!
ES9023 / WM8804 S/PDIF "Subbu DAC V3" GB Interest korben69 Group Buys 1035 6th May 2018 06:16 AM
ES9023 / WM8804 S/PDIF DAC Group Buy unixdeveloper Group Buys 693 1st May 2018 01:04 PM
Case for "ES9023 / WM8804 S/PDIF DAC Group Buy" rvrazvan Digital Source 3 27th July 2014 08:37 AM
Power Supply PCB for ES9023 / WM8804 S/PDIF DAC Group Buy unixdeveloper Group Buys 145 29th July 2013 12:55 PM
WTB V2.6 PCB for ES9023 / WM8804 S/PDIF DAC –SUBBU DAC grufti Swap Meet 0 26th November 2012 05:51 PM
