Group Buys Members group buys
Versatile and comfortable passive pre-amp
Old 23rd March 2015, 01:46 PM   #771
Rudi_Ratlos is offline Rudi_Ratlos  Germany
Rudi_Ratlos's Avatar
I am very happy that METAL is "on board" again!
Together we will get rid of the motorized analog dual-potentiometer (which is imprecise, costs a lot, ...is an anachronism) and will replace it by a laser-trimmed dual digital MCP42100 potentiometer (being followed by a VCCS).
The MCP42100 will give you 256 (!) wiper steps for both inline potentiometers!
I have attached two images of our current progress.
We are working hard on it!
Be sure: this will be one of the best-sounding, very well-priced and versatile PREs that you have ever listened to!
It will take some time though. Neither METAL nor me are in a hurry.
Best regards - Rudi_Ratlos
P.S.: The software (the PIC's firmware) to be programmed (will be done by METAL) is the biggest part for a successful implementation!
Old 23rd March 2015, 01:54 PM   #772
atupi is offline atupi  Romania
This is great news Rudi! I have a proposal and a question. The proposal is to put also two switch to be able to adjust volume manually not only from remote control.
This digital pot will be like a retrofit module for the old preamps or will be a completely new version of preamp with relays and everything ?
Rega RP-1/Simplistic RIAA by Salas/ DCB1 clone/ MyRef Fremen Edition/FC-100/ XTZ 99.26 MkII speakers
Old 23rd March 2015, 02:11 PM   #773
Adrian: there will be no knobs neither switches on the front-panel of my SYMASYM's case!
I like to sit in my armchair and do everything via remote-control!
The "new R_PRE-PCB" will no longer support an analog motorized potentiometer with Motor- H-bridge.
We have entered the 3rd millenium - didn't we?
Kind regards - Rudi_Ratlos
Old 23rd March 2015, 02:14 PM   #774
Sometimes remote controls likes to play hide and seek with theirs owners
It will be a completely redesigned preamp module with digital pot ?
Old 23rd March 2015, 04:11 PM   #775
redjr is offline redjr  United States
Originally Posted by Rudi_Ratlos View Post
....But since the VCPre (its LDRs) is not able to drive a long pair of RCA-cables and (or) a low-impedance amplifier, I decided to connect the VCPre's output to a buffer.
I have chosen Calvin's buffer.....
I know I was late to the VCPre party, but I had much bigger projects to deal with over the past 18 months. And since I'm slow and meticulous, and still work full-time, it takes me many, many evenings and weekends to complete a project.
So, what exactly is the difference between a pre-amp and a buffer? Or, are they essentially the same? I gather from reading they are the same. I don't have long interconnects between my gear so would the VCPre be enough of a pre-amp to use. BTW, I built the Doug Self preamp a couple of years ago when it was featured in Elektor, which I use in my main system, but I have other amps where I want to use the VCPre.
I've read much on the B1 Buffer Salas and have order the PCB for it along with the parts. Could I use the VCPre to feed the B1 buffer like you did with the Calvin? Are there any benefits of doing so aside from allowing longer RCA interconnect runs? I would still use the VCPre as the signal switcher over the manual method used on the B1.
My next big project is your Symasym amp with the newest digital pre as an integrated amp. Would this be a good project to incorporate the B1 Buffer? I will start on the Black Beauty PCB soon.
Thanks for all you hard work on these projects!
Rick
redjr
Old 23rd March 2015, 04:17 PM   #776
VcPre is basically an attenuator+source selection module. Of course you can add a Calvin or a B1 for easier driving. Both Calvin or B1 are buffers meaning they are not amplifying or attenuating just matching impedances.
Old 23rd March 2015, 08:30 PM   #777
metal is offline metal  Jordan
metal's Avatar
Here is what I 've got for you today, more later :- )
Old 24th March 2015, 02:10 AM   #778
Default Motorized VC
Is the motorized volume control designed to be used manually as well? If so, does it need to be energized? I tried to manually rotate the shaft on one of Bourns I got for the VCPCre and it's very, very stiff. Near impossible to move, or move smoothly for sure. Does energizing it free up the gears or something?
redjr
Old 24th March 2015, 03:27 AM   #779
Should move freely even manually. Maybe your pot is broken or something enteren into mechanism.
Sent from my iPad using Tapatalk
Old 24th March 2015, 12:09 PM   #780
They've been in the plastic bags since I got them over a year ago. Hum... I'll check the other one. They move anything but freely.
redjr
Versatile and comfortable passive pre-ampHide this!Advertise here!
Designing a versatile pre with balanced and unbalanced in/out Nikon1975 Analog Line Level 56 28th December 2012 10:56 PM
Passive pre-amp Davy Solid State 20 25th August 2008 09:11 PM
Is this possible from a passive pre-amp? mr.duck Everything Else 7 3rd December 2006 11:57 AM
passive pre amp mschwilson Solid State 10 27th July 2005 01:43 PM
Passive pre amp vs powered pre amp fatmarley Solid State 21 21st November 2003 02:01 PM
