Group Buys Members group buys
Versatile and comfortable passive pre-amp
Old 11th June 2013, 02:50 PM   #21
Rudi_Ratlos is offline Rudi_Ratlos  Germany
Rudi_Ratlos's Avatar
Jorge: METAL and I will definitely offer this PCB in a group-buy. METAL is currently re-working the ÁProcessor's software (firmware)
to include the changes (f.e.: Soft-Power-On interface, HTBypass interface, ...), while I do the layout-changes
and keep the documentation up-to-date.
I suppose to start the group-buy next week, but we have to settle upon what I will offer in this group-buy (PCBs, pre-programmed ÁProcessor,
for sure, what else?) first.
Wineds: the schematics are posted in the documentation ("Builder's Manual") that I will send to all participants of the group-buy.
The VCPre is communicating its status on a 1x16 chars, HD44780 compatible LCD display. I will use a display with 9mm big letters.
You may use the display, but you need not.
The status of the source selection relays, the HTBypass relay and the Soft-Power-On relay will be reported on LEDs as well.
Find attached 2 pictures.
The left one shows how my front panel will look like, while the right one shows the front panel of a German DIY-friend of mine.
He is using McIntosh-like panel meters that are driven from a small DIY-PCB.
Best regards - Rudi_Ratlos
Old 11th June 2013, 03:36 PM   #22
@Voxxonline: I do see no reason, why this is not doable.
The VCpre needs 2 voltages: 5VDC (7805) for the analog and digital world and 6VDC (7806) for the Motor-H-Bridge
to drive the motorized potentiometer.
The power-consumption of the VCPre is: 1-2 source relays (source-input and HTBypass, if HT is selected), 2-3 LEDs
(Active/Sleep-LED, 1-2 source-input relay LEDs), LDR-LED current, LCD display, ÁProcessor: round about 100mA.
The motorized-potentiometer needs about 100mA if processed.
I am not aware of any hum or "electronic smog" that the VCPre generates, nor do the German DIYers, who have already built the VCPre.
Old 11th June 2013, 03:37 PM   #23
voxxonline is offline voxxonline  United Kingdom
voxxonline's Avatar
That is the approx price of complete build?
How to find time to finish my projects ?
Old 11th June 2013, 03:46 PM   #24
voxxonline's Avatar
And physical size of the boards please
Old 11th June 2013, 03:53 PM   #25
jean-paul is offline jean-paul  Netherlands
diyAudio Moderator Emeritus
jean-paul's Avatar
Hi Rudi, nice project. I would not use Molex KK for 230 V though. Better use a Phoenix MKDS for that. If you use a FR5 fuse it will fit.
Did you measure the device ? The transformer is pretty close to the audio circuitry. I think your GB will be a successful one as it is a complete versatile device. A buffer would have made it suitable for preamp use with separate power amps.
It's only audio. Member of the non modular PCB design committee
Old 11th June 2013, 03:53 PM   #26
@Voxxonline:
I am currently calculating prices (they depend of course upon the amount of orders), but I can give you the size of the PCBs immediately:
VCPre - PCB: size is 100 x 100mm
SPO - PCB: size is 80 x 70mm
HT - PCB: size is40 x 29mm
P.S. Jean-Paul: I will look for PHOENIX MKDS in my EAGLE-library.
Old 11th June 2013, 04:33 PM   #27
jean-paul's Avatar
Hi please look for this one: MKDS 1,5/2
http://www.farnell.com/datasheets/100425.pdf
Old 11th June 2013, 04:39 PM   #28
voxxonline's Avatar
Hi Jean Paul!
How do you think this pre would mate with Subbu dac + gb buffer?
Old 11th June 2013, 04:40 PM   #29
Jean-Paul: here we are.
Old 11th June 2013, 04:43 PM   #30
jean-paul's Avatar
That depends on the input impedance of this pre. The Subbu DAC does not like very low impedances. I take the liberty of asking some questions to Rudi:
1. What is the input impedance of the VCPre ?
2. At what load starts it to choke ?
3. Why no buffer at the output ?
That is better Rudi. Don't you think the SPO tracks run too close to AC pins of the transformer ? Also upper 230 V AC track from the fuse to the primary pin can be adjusted so that it stays further away.
* the whole input section can be moved somewhat closer to the upper side of the PCB. The further away from the transformer the better it is.
Versatile and comfortable passive pre-ampHide this!Advertise here!
Designing a versatile pre with balanced and unbalanced in/out Nikon1975 Analog Line Level 56 28th December 2012 10:56 PM
Passive pre-amp Davy Solid State 20 25th August 2008 09:11 PM
Is this possible from a passive pre-amp? mr.duck Everything Else 7 3rd December 2006 11:57 AM
passive pre amp mschwilson Solid State 10 27th July 2005 01:43 PM
Passive pre amp vs powered pre amp fatmarley Solid State 21 21st November 2003 02:01 PM
