Group Buys Members group buys
Versatile and comfortable passive pre-amp
Old 10th June 2013, 11:37 AM   #11
wineds is offline wineds  Australia
Rudi is there any way one of the inputs could be configured as a home theatre (ht) bypass input? Or fourth input added with this functionality?
Mute could possibly also be implemented using software to wind the pot down and then later back to the same position? This might allow the existing mute relay to be used for ht bypass perhaps?
Nice work BTW!
Old 10th June 2013, 11:50 AM   #12
Wirehead_be is offline Wirehead_be  Belgium
Wirehead_be's Avatar
Definitely interested as well
Old 10th June 2013, 04:21 PM   #13
Rudi_Ratlos is offline Rudi_Ratlos  Germany
Rudi_Ratlos's Avatar
@Wineds, Wirehead.be: I hope that I understand correctly, what you want.
I am not a "multimedia-man" !
You have access to the un-attenuated and the attenuated audio-signals as shown in the image below.
As I understand you, you want to bypass the attenuation and feed the signal directly to your AMP, in case you select "Home Theatre" as source.
I will not offer this feature on the standard VCPre-PCB for these 2 reasons:
- it is very (!) hard to insert an additional relay on current VCPre-PCB version
- I (myself) do not like to put another strain / load (relay) on the audio-signal
But I will offer you an additional PCB that will fulfill your needs:
Being driven from the VCPre-PCB, this small enhancement will let you switch between attenuated and non-attenuated audio signals.
I hope that this solution will suit you.
Best regards - Rudi_Ratlos
Old 10th June 2013, 04:54 PM   #14
Hello Rudi, well this is exactly what I need in it's present form. I was thinking of building an Arduino-based LDR attentuator, with relay input channel selector. But this fits the bill 100%
Old 10th June 2013, 05:12 PM   #15
@WireHead.be: to layout the supplementary PCB takes me 5 minutes.
Here it is:
Old 10th June 2013, 07:14 PM   #16
goldkenn is offline goldkenn  Hong Kong
Originally Posted by Rudi_Ratlos View Post
Goldkenn, Bill: I have added two 2-pole connectors in front of the mute-relay.
Does it suit you?
It seems great!
Old 11th June 2013, 12:55 PM   #17
@Wineds, Wirehead.be: find attached the current layout of the VCPre - PCB.
I put the HTBypass-connector on the bottom right side.
It has 3 pins: VCC, GND and a ÁProcessor output-pin that will connect to the small HTBypass-PCB.
Old 11th June 2013, 02:17 PM   #18
nice job RudI. are you going to post the schematics?
Old 11th June 2013, 02:29 PM   #19
jcastellano is offline jcastellano  Spain
Thumbs up I am also interested
Gentlemen,
my DIY-friend METAL and I have been working for quite a while on a passive pre-amp that shall be versatile (give us all the functionality
that we need) and comfortable, so we can sit in our armchair and control everything per remote-control-unit.
This is the current result of our project:
http://abload.de/img/display012a0xwe.jpg
This PCB (I call it VCPre hereafter) has the following functionality:
- Source selection of up to 3 input sources
- Mute function
- Attenuation, either based on a LDR - solution or a traditional AUDIO potentiometer
- Support of motorized potentiometers
- Display of attenuation
- Display of current temperature of your heatsinks
- Implementation of a Standby / Resume-from-Standby function for your amplifier
- Status-display on a 1x16chars LCD module
- Every function can be controlled by an infrared remote-control unit
The functionality of the VCPre is accomplished by the use of a PIC 16F886 ÁProcessor.
I myself am using the current VCPre PCB-version in the build of my FC-100 amplifier, it works flawlessly, and I did not yet receive any complaint
from any of the German DIYers, who have already installed the PCB.
http://abload.de/img/neverbeforehavelisten5hzwb.jpg
If there is some interest, I will start a group-buy offering the PCB(s), documentation, pre-programmed ÁProcessor, hard-to-get components (if any), ...
Hi Rudi,
I am interested in this project if ever convert to group buy, I will participate. Thanks for your great work.
Jorge
Old 11th June 2013, 03:05 PM   #20
voxxonline is offline voxxonline  United Kingdom
voxxonline's Avatar
I might do as well. I would like to integrate it with dac in one Box. Do you Think it is doable?
How to find time to finish my projects ?
Versatile and comfortable passive pre-ampHide this!Advertise here!
Designing a versatile pre with balanced and unbalanced in/out Nikon1975 Analog Line Level 56 28th December 2012 11:56 PM
Passive pre-amp Davy Solid State 20 25th August 2008 10:11 PM
Is this possible from a passive pre-amp? mr.duck Everything Else 7 3rd December 2006 12:57 PM
passive pre amp mschwilson Solid State 10 27th July 2005 02:43 PM
Passive pre amp vs powered pre amp fatmarley Solid State 21 21st November 2003 03:01 PM
