Primrose(SumR Audio) Toroid GB - Page 60 - diyAudio
Go Back   Home > Forums > Commercial Sector > Group Buys
Group Buys Members group buys
Old 22nd January 2014, 10:07 AM   #591
Originally Posted by alazira View Post
I have the ones for EUVL's F5X and, without a load, they are silent. Hopefully it will remain so as it would be a PITA to send these to Canada.
In my EUVL F5X under load the Sumr’s buzz.
Not excessively, I can only hear it from a couple of inches away.
I kind of expect this is normal, especially considering the current draw.
Old 22nd January 2014, 11:30 PM   #592
BDP is offline BDP  United States
I would be satisfied if I couldn't hear it five feet away, but I can't accept hearing the buzz in the other room.
Old 22nd January 2014, 11:40 PM   #593
buzzforb's Avatar
It is obvious you have a bad one. Contact Richard and he will rectify the situation. He has handled this very professionally up to this point and I don't expect it to change.
...Shape the sound , Man!
Old 3rd February 2014, 11:18 PM   #594
labjr is offline labjr  United States
Originally Posted by Tea-Bag View Post
How about someone in the know establish a basic loading test with minimal parts etc to test for mechanical noise. Something we can standardize on for in the cheap. If I have the parts already - I will do it and send it on to the next guy....
I'm wondering if someone has come up with a test procedure yet? Preferably something that doesn't need a variac as I don't have one.
Old 4th February 2014, 12:34 AM   #595
buzzforb's Avatar
Take your rail voltage and divide the bias current your amp will be set at. The number you get is the value of the resistor you should load your PSU with tied from each rail to ground. Just make sure you have adequate dissipation ratings. Probably easiest to parallel multiple 3W resistors. Light bulbs will also work, but will be more e expensive in the end. For most FW amps, which use 22V rails and about 1-2A bias, you are looking at about 10R. You could buy a large resistor or get 10-20 cheap 3w types.
Old 4th February 2014, 01:05 AM   #596
I have a bunch of 6 ohm 50 watt resistors and a power supply board built up. I'll try to wire it up when I have time. Thanks
Old 6th February 2014, 07:04 AM   #597
ByronInPortland's Avatar
Thumbs up My Pimrose in Action
I forgot all about this thread, and was surprised to see it still alive. I finished my amp using my Pimrose transformer long ago. I'm very happy with this tranny. Thank you, Buzzforb for arranging this group buy!
Old 14th June 2014, 07:07 PM   #598
Originally Posted by BDP View Post
I finally installed the SumR transformer as part of the group buy (400VA, 22VAC) and it mechanically buzzes badly, not usable for my standards.
While I was waiting for the SumR transformer I was testing a single channel F4 with a 120VA, 22VAC Plitron and it was dead silent at full bias.
I would suggest everyone involved in the group buy test their transformers before too much time passes.
BDP
I wanted to report back that SumR exchanged both transformers and both are completely quite. Richard was very good to correspond with. I never heard what the problem was with the first batch, but these two units perform perfectly.
BDP
Old 14th June 2014, 08:21 PM   #599
BDP
Who paid the shipping cost?
Old 5th July 2014, 09:57 PM   #600
RKH is offline RKH  United States
Default Testing
I finally got around to setting up a test rig for my SumR transformers.
- Variac supplying the transformer (so I can ramp the voltage slowly)
- Secondary output of transformer feeding a bipolar PSU ("+"-ground- "-")
- Output of PSU feeds load of 300-Watt light bulbs (up to 3) wired in parallel
-- I can change load by inserting or removing bulbs.
I am measuring the DC current through and the voltage across the load. Here is what it looks like. Quantitative report to follow, but in an initial test I can hear buzzing from about 3 feet away.
Ryan
Lighten up while you still can ...
FS: F5X GB chassis and all GB parts Studley Swap Meet 6 21st May 2013 11:47 AM
Kits to start an audio electronics lab GB ashaw Group Buys 0 30th September 2011 01:28 PM
GB for R2R audio volume / input selection pcb danzup Group Buys 147 22nd May 2011 04:42 PM
1kva Toroid GB Sweden widerström Group Buys 0 18th March 2008 09:45 PM
Conrad Heatsinks GB in GB/EU bremen nacht Parts 1 1st February 2006 08:48 PM
Copyright ©1999-2017 diyAudio
