Group Buys Members group buys
Primrose(SumR Audio) Toroid GB
Old 23rd February 2013, 08:46 PM   #111
buzzforb is offline buzzforb  United States
buzzforb's Avatar
I am in Georgia and unfortunately required to stay longer than expected. I will close when i get back. Until then, turn away from temptaion
...Shape the sound , Man!
Old 23rd February 2013, 08:53 PM   #112
skunark is offline skunark  United States
RKH - 2 x 600VA or 2 x 800VA (whatever is best for V3 monoblocks)
Justin - 2 x 600VA
gmant123 - 2 x 400VA
ra7 - 2 x 400VA
Guiness - in for a few no matter what you guys decide
Tea-bag - 1 400va@18v and 800 or 1000@24v
billyK - 800VA 24Vac x 2 - 1 unit, 400VA 24Vac x 2 - 2 units total of 3 units
wirewiggler - 1 400VA X 2 for F6,
qusp - 2 x 400VA
pchw - 1 x 1000VA 24Vac*2
Russellc 1 x 1000VA 24 V x2 (For V2) may be in for 2 more.
PKI — 4x400VA@18Vx2 (universal 115/230 primary voltage)
RDK - 2 x 800VA (for "future proof" v3 mono block)
Skunark - 2x800VA@24Vx2 for F5T V3, 2x600VA@18Vx2 for F6, 2x800VA@45Vx2 for HoneyBadger, potted if possible
Ryssen 1x400VA for F6
Tehrkn - 2 x 1000VA@24V
necplusultra - 2 400va@18v and 1 1000@24v
etoiledusoir-1X400va@18v
Lo_tse - 2 x 800VA
pcb121055 - 2 x 1kVA@26x2
vanofmonks - 1 x 400va@18vx2
wjh – 1 x 800VA@24Vacx2
1MOR - 2 x 800va 24V
quan-2x 400VA@45x2(230V)
petefrontiers - 2x 400VA for F5T V2
bugzbunny - 2 x 800 VA at 24V for F5T V3, 1 x 400VA at 18V for F5Clone, 1 x 400 VA for F6 Convertible (not sure about voltage for this one), 1 x 800VA (x2 45V, equiv to Antek AN8445) for the HoneyBadger Amp; prefer potted for all 5. And: 2 x 500VA 2x15V Transformers for F5X (not potted)
Mordikai 4x1000va@24v
Mordikai 2x400va@18v
luvdunhill (qty 4) 2 x 22VAC, 350-400VA <= 125mm diameter
alazira 2 x 500VA@15x2
SRMcGee - 1 x 800va @ 24VAC, 1 x 800va @ 32VAC and 2 x 1000va @ 32VAC
BDP (qty 2) 2 x 22VAC, 400VA, potted
jcastellano - 1 x 400va@18vx2
jcon2 -(qty 2) 800VA or 1000VA @ 24va
cristianr - 1 x 800VA@24Vacx2
justadude - qty 1 - 22v @ 400va
Flodstroem 4 x 600VA, sec @ 41Vx2 (eg. 2 matching secondary outputs) + 14Vx1@1A / 230V Prim. (Krell KSA100 II monoblocks)
1 x 600VA, Sec @ 47Vx2 (eg. 2 matching secondary outputs) + 14Vx1@1A / 230V Prim. (GB300D) all 5 pcs potted/epoxied
bk856er 1x 800VA @ 24Vx2
danielutzu - 1x800 VA at 18Vx2 (for F6); 2x800VA at 24Vx2 (for a F5T v2 balanced or for a BA3 balanced); all 3 potted, if possible
cefud - 2x800VA @ 24Vx2 (or whatever is best for V3 monoblocks)
Grimberg - 4 x 400VA@18Vx2
den054 - 1 x 400VA@25VACx2 (115/230VAC primary)
d to the g 1x 400VA w/2x18V /2x 400VA w/2x24V, with additional 15V 1A secondary for L'Amp
triode4 - 2 x 1000VA 24 V x2 (For V2), 4 x 400VA 28 V x 2 ,15 V x1(for L'Amp SIT)
labjr 2 x 400VA @ 18V
zman01 - 1 x 600VA @18Vx2 for F6 (115/230 VAC primary)
I've updated my list and noticed that D to the G left out Bugzbunny update's, which should be fixed above, but probably good to review again.
Old 25th February 2013, 11:24 PM   #113
David AM is offline David AM  United States
David AM's Avatar
Justin - 2 x 600VA
ra7 - 2 x 400VA
qusp - 2 x 400VA
Lo_tse - 2 x 800VA
David A.M. 1 x 400VA@20Vx2 or as close as possible. Thanks.
Old 27th February 2013, 12:06 AM   #114
joesch1999 is offline joesch1999  United States
I need a 800 va suitable for the ba2 can someone help me out? or is this over
Old 27th February 2013, 12:11 AM   #115
buzzforb's Avatar
Here ya go fellas. PLease check entry as well as listing the secondary voltages you want. Cell may be too small as is, but we will adjust. Hopefully the order is large enough that they will accommodate all the request, but some may have a decision to make if they want a to maintain discount. We will have to see. Lets get it wrapped up so we can finalize pricing.
https://docs.google.com/spreadsheet/...mc&usp=sharing
Old 27th February 2013, 12:44 AM   #116
bk856er is offline bk856er  United States
bk856er's Avatar
Is that a read-only doc? My VA is wrong, but I can't edit.
BK
Old 27th February 2013, 01:02 AM   #117
buzzforb's Avatar
Ill change it.
Old 27th February 2013, 01:06 AM   #118
buzzforb's Avatar
Its done. Ill add it to my sig, tomorrow.
Old 27th February 2013, 01:20 AM   #119
ok 800va good for ba2 do i need secondary?
Old 27th February 2013, 01:23 AM   #120
labjr is offline labjr  United States
I'm curious how the discount will work? Will it be on the grand total, each VA size or each identical VA size and voltage combination?
I may be interested in ordering a couple larger ones for future projects that aren't even conceived yet because the price would be basically the same as I paid for a Plitron 400VA Group buy years ago.
Primrose(SumR Audio) Toroid GBHide this!Advertise here!
FS: F5X GB chassis and all GB parts Studley Swap Meet 6 21st May 2013 11:47 AM
Kits to start an audio electronics lab GB ashaw Group Buys 0 30th September 2011 01:28 PM
GB for R2R audio volume / input selection pcb danzup Group Buys 147 22nd May 2011 04:42 PM
1kva Toroid GB Sweden widerström Group Buys 0 18th March 2008 09:45 PM
Conrad Heatsinks GB in GB/EU bremen nacht Parts 1 1st February 2006 08:48 PM
