Group Buys Members group buys
Amanero Isolator/Reclocker GB
Old 13th December 2013, 08:22 AM   #911
acko is offline acko  Australia
My pleasure!
AckoDAC Project
Old 2nd January 2014, 10:08 PM   #912
BuildMeSomething is offline BuildMeSomething  United Kingdom
acko...
Ordered a single board from you on New Years Eve through the site, delighted by the amazingly quick response and dispatch notice ... Couldn't ask for more
Might be ordering another pair of the isolators/re-clockers, just need to figure out what bits I need surrounding a USB>miniSharc>2xDAC build.
Paul.
Listening with Gusto!
Old 3rd January 2014, 12:05 AM   #913
hochopeper is offline hochopeper  Australia
Paul, I'm busy here today but just a quick note to let you know that the minisharc will only work with usb slave mode sources, you'll need to be careful with which isolator chip you select ...
Chris
Old 3rd January 2014, 11:00 AM   #914
Hi Chris and thanks for the quick warning... I've had a good read on the miniSharc and realise adding I2S USB input isn't going to be straight forward. I'll also need inline Sample Rate Conversion ... that or re-sample all my digital music from 44.1 to 48MHz
My initial thought is Amanero > acko Iso/reclocker > TPA Metronome > miniSharc ... or something like that.
Paul.
Old 4th January 2014, 07:36 PM   #915
Originally Posted by hochopeper View Post
... you'll need to be careful with which isolator chip you select ...
Chris
You mean use either the IL or SI chip rather than the quicker Potato one?
Old 5th January 2014, 02:31 AM   #916
Because the minisharc must be i2s master the mclk signal becomes and input rather than output and the isol chips are directional so the si/nve chip data sheets should show you the part number to allow that.... Would need to bypass reclocking I think too. I would potentially use this on the output only of the minisharc rather than input ... That would keep computer and DSP noise separate from DAC
Old 5th January 2014, 12:21 PM   #917
Got you now ... Want to try using the TPA Metronome in full slave mode [input & output sides as slave] between the USB module & miniSharc. This should allow both USB and miniSharc to operate as master, the Metronome takes BCLK, LRCK & SD from USB [input side] and converts SR based on MCLK, LRCK, BCLK from miniSharc [output side]
USB needs to be 24 bit I2S 44.1 to 192MHz and SR output would be set by the minisharc plug-in [48 or 96MHz]. Metronome would be set-up as in/out slave, 24 bit I2S input and 24bit I2S output. SRC & output is based upon comparing input side LRCK to output side LRCK.
Will be a couple of weeks before I have all the bits and can physically try this out...
Was also thinking about using the iso/re-clk on the output side, between miniSharc & 2 x Curryman DACs... Long run, I'd like to go with a multichannel TPA Buffalo III but would require a multichannel version of Ian's FIFO Kit!?
Paul
Old 8th January 2014, 01:33 PM   #918
twluke is offline twluke  Japan
Originally Posted by acko View Post
Check updates on website below...
Well, I've tried to add myself to the GB spreadsheet for this AKU384 but the sheet appears write-protected for now. How can I preorder this board? Should I wait for the available time in February?
twluke
Old 8th January 2014, 06:22 PM   #919
twluke
Thank you for pointing out! Spreadsheet is enabled now for pre-orders
AckoDAC Project
Old 8th January 2014, 10:42 PM   #920
Thank you for your quick response. I've just added my name to the list.
twluke
Amanero Isolator/Reclocker GBHide this!Advertise here!
DQ DAC 2, BIII SE, Tube-I-Zator, Arduino, Amanero Build DQ828 Digital Line Level 94 28th December 2013 10:29 PM
FS: F5X GB chassis and all GB parts Studley Swap Meet 6 21st May 2013 12:47 PM
Amanero 384 with Kernel Streaming/Wasapi win764bit stamatiski Digital Source 9 18th November 2012 03:23 AM
Conrad Heatsinks GB in GB/EU bremen nacht Parts 1 1st February 2006 09:48 PM
