Group Buys Members group buys
Amanero Isolator/Reclocker GB
Old 9th July 2013, 01:56 PM   #761
MisterRogers is offline MisterRogers  United States
Can you say Audio?
Awesome Acko - thanks! I'm shelved it until we get more specifics. May be just me, but I can't get slave mode flashed. Tried every combination I can think of.
Originally Posted by acko View Post
Have requested Amanero for further assistance and will advise. Also new cpld slave 45/49 firmware and update procedures will be released soon
Old 18th July 2013, 09:55 AM   #762
DQ828 is offline DQ828  Australia
DQ828's Avatar
Board received, thank you
Old 20th July 2013, 02:34 PM   #763
Can you say Audio?
I'm trying to work out some CKSEL issues with my full sync install (posted a question in the Amanero thread), but I was wondering - how can I best force X1 out and X2 in (simulate pin 11 high)? I'm thinking ground pin 2 and power pin 3 of J10? would 5V on pin 3 be too much?
Old 20th July 2013, 11:48 PM   #764
acko is offline acko  Australia
Default Amanero CKSEL Issues
Yes, you can manually select the clocks on the AKX302 module. Obviously I was thinking this would done automatically by Amanero but from the looks of it there may be a firmware issue with the Amanero unit. Until this is sorted try manually:
1. Disconnect any J10 (CKSEL) connection of AKX302 to the reclocker boards (S01/S02).
2. Tie pin#2 and pin#3 together and use the combined lines to connect/disconnect to XO 3.3V supply to select clocks accordingly.
e.g. Pin2/3 open -> X1 selected. Pin2/3 to 3.3V ->X2 selected.
I would not advise connection of the above to 5V supply as the XOs are running on 3.3V
Let us know if this works
AckoDAC Project
Old 22nd July 2013, 07:15 PM   #765
RollE2k is offline RollE2k  Sweden
Recieved the last PCB today. Thanks alot acko.
Although i will not build it until later when i start my headphone amp project! :-)
Old 22nd July 2013, 10:08 PM   #766
bk856er is online now bk856er  United States
bk856er's Avatar
Received my PCB today in Calif - thanks!
BK
Old 22nd July 2013, 10:13 PM   #767
palmito is online now palmito  United States
palmito's Avatar
Default Received my pcb today too!
Thanks Acko!
Old 22nd July 2013, 10:43 PM   #768
Can you say Audio?
Thanks Acko; it'll be great when these 'bleeding edge' applications of the Amanero are worked out. Your instructions make sense. I had to pack up my bench (in the middle of a move), so it'll be awhile before I can test and push forward. Hopefully, we'll have another firmware drop by then. Btw, boards arrived - thanks again!
Old 23rd July 2013, 07:27 AM   #769
fcaton is offline fcaton  France
Received my board yesterday.
Thanks Acko!
Old 23rd July 2013, 10:54 AM   #770
DQ828's Avatar
I know this is no great achievement, but I have managed to get the Isolator working with the Amanero & the Amanero power from a separate supply. I bit of Bach playing now
Amanero Isolator/Reclocker GBHide this!Advertise here!
DQ DAC 2, BIII SE, Tube-I-Zator, Arduino, Amanero Build DQ828 Digital Line Level 94 28th December 2013 09:29 PM
FS: F5X GB chassis and all GB parts Studley Swap Meet 6 21st May 2013 11:47 AM
Amanero 384 with Kernel Streaming/Wasapi win764bit stamatiski Digital Source 9 18th November 2012 02:23 AM
Conrad Heatsinks GB in GB/EU bremen nacht Parts 1 1st February 2006 08:48 PM
