Group Buys Members group buys
Amanero Isolator/Reclocker GB
Old 6th May 2013, 03:26 AM   #591
hochopeper is offline hochopeper  Australia
bigpandahk,
Are you inputting 5V on J6? Both 3.3V headers are for the DAC side.
Do you have the schematic, it shows J4/J5 connected together. Check with a meter if they're connected ...
Chris
Old 6th May 2013, 03:36 AM   #592
bigpandahk is offline bigpandahk  Hong Kong
Thanks qusp.
The 5V and the middle 3.3V are the isolated side and either one shall be powered by the DAC.
another 3.3V is from Amanero, am I correct?
Old 6th May 2013, 03:38 AM   #593
Originally Posted by hochopeper View Post
bigpandahk,
Chris
Oh, both are for DAC side. Thanks hochopeper.
I don't have the schematic, where can I find it?
One more question : I understand the RCLK is for reclock and I will connect it to i570 MCLK. How about for async mode? shall I connect the RCLK to MCLK of the isolator?
Old 6th May 2013, 04:08 AM   #594
Ask Acko for a copy of the schematic ...
I'm not sure what you mean by the last question??
Old 6th May 2013, 04:25 AM   #595
For re-clocking in sync mode, I will connect the i570-MCLK to the RCLK of the isolator.
If run in Async mode, do I still have to provide clock for the FF? is is just connect the MCLK (I believe it's from Amanero) on the isolator board to the RCLK?
Old 6th May 2013, 08:22 PM   #596
RollE2k is offline RollE2k  Sweden
Regarding CKSEL, i know SPDIF uses recovered clock - but is there any SPDIF-reciever that can output something that can be used as CKSEL?
Old 7th May 2013, 10:10 AM   #597
so i could at least isolate and reclock the signal with 90M/98M XO?
Old 10th May 2013, 10:10 AM   #598
DQ828 is offline DQ828  Australia
DQ828's Avatar
I know this is a bit OT but I was interested to know what you guys thought was the most appropriated wire gauge for:
1) Signal wire, say from DAC to RCA's etc
2) Hookup wire, say from the isolator to DAC or arduino to other component.
3) Internal Speaker wire say from, Amp to speaker terminals
4) General low voltage say 3.3v to 12v power supply wire.
Old 10th May 2013, 10:32 AM   #599
Wire gauge is probably less significant here than capacitance and signal/return/shield geometry for electric and magnetic field rejection.
22 or 24awg is what I end up using though I guess, though I don't think about that so much.
If we're talking power lines, whatever is closest, for signal wires, it depends on the signal, for low freq signal like i2c, still whatever is closest and fits in the PCB hole or crimp connector whichever the case may be.
Depends on speaker efficiency, amp supplying compression driver vs a 4ohm low efficiency midwoofer(s) would probably demand different wire gauge. 14awg would probably cover most practical cases though off the top of my head.
See 2 above. Unless it is wire for a battery charger, then I'd think about it a bit more since they can have a few amps going down them. For anything less than an amp I don't fuss too much.
Old 11th May 2013, 08:42 PM   #600
Mull3t is offline Mull3t  United States
I'm curious how to get on a list for a few pcbs. I looked and found a list that I have to be given access to via google. Is this the list?
Thanks,
Mull3t
Amanero Isolator/Reclocker GBHide this!Advertise here!
DQ DAC 2, BIII SE, Tube-I-Zator, Arduino, Amanero Build DQ828 Digital Line Level 94 28th December 2013 09:29 PM
FS: F5X GB chassis and all GB parts Studley Swap Meet 6 21st May 2013 11:47 AM
Amanero 384 with Kernel Streaming/Wasapi win764bit stamatiski Digital Source 9 18th November 2012 02:23 AM
Conrad Heatsinks GB in GB/EU bremen nacht Parts 1 1st February 2006 08:48 PM
