Group Buys Members group buys
Amanero Isolator/Reclocker GB
Old 13th April 2013, 05:10 AM   #541
nvduybom is offline nvduybom  Viet Nam
nvduybom's Avatar
Thanks grufiti. It is ready for testing .
http://www.vnav.vn/forum
Old 16th April 2013, 12:35 PM   #542
miksi is offline miksi  Serbia
Acko, just to inform you, I received the isolator boards last week(1 month from sending). I have some ISO7240M from TI samples, can I use it instead of the IL715?
I think we are pretty much done with the Clock module design! Just checking all the layout and getting it ready for fab
Do you have final BOM for the AKX302 module? I will do some ordering so it will be nice to incude clock parts.
Old 17th April 2013, 07:43 AM   #543
acko is offline acko  Australia
Glad to hear. Surprised by how airmail travels to certain places these days!
Yes, you can use ISO7240-looks pin compatible
These will be ready by next week. Boards are in fab now and expecting by end of next week
AckoDAC Project
Old 17th April 2013, 07:49 AM   #544
hochopeper is offline hochopeper  Australia
Originally Posted by nvduybom View Post
Hi acko ,
I just need the function isolator on S01 board, so I can only solder with minimal components such as PSU, Isolator chip ?.
Thank you
I know I'm late in replying but here goes anyway, my S01 is even more minimalist. Just the isolator chip and two caps, power supply is external (5V from Ian's FIFO, the FIFO input is 5V tolerant).
I will be building up a fully loaded S02 though.
Old 23rd April 2013, 05:55 PM   #545
iskwon is offline iskwon  South Korea
iskwon's Avatar
Default Reclocker GB entered
I entered 3 sets each for GB.
I hiope I am not too late.
Old 24th April 2013, 02:34 AM   #546
palmito is offline palmito  United States
palmito's Avatar
Originally Posted by hochopeper View Post
S01 is even more minimalist. Just the isolator chip and two caps...
For the feeble minded... would the above be C1/C4/U1 for the minimalist setup?
Also, on post #382, which "see attached" attachment should we refer to? I would like to go with option one listed on that post, just want to check that I understand clearly the connections/location.
Thanks.
Old 24th April 2013, 03:11 AM   #547
Exactly, you need to be mindful of what voltage you supply on J3, that is going to be the voltage seen by your DAC (or FIFO in my case).
Thanks.
Not sure what happened there, here is the image I meant to attach back then:
Hope that helps my previous post make more sense!!
Chris
Old 24th April 2013, 03:17 AM   #548
palmito's Avatar
Chris
Thanks for the quick reply Chris. It's for Ian's FIFO, so 5v should be ok?
The attachment fails to open for me though!
Old 24th April 2013, 03:30 AM   #549
Yeah for FIFO 5V is ok, there is a 5V output on the FIFO (J5 on the FIFO pcb) that I use to supply J3 on my the S01.
Not sure what's going on with that attachment, I simply attached it to the post on the forum. It works in one browser here but not others, odd. I will look into it and try again. Until then, if you want just PM me your email address and I can email it to you ...
Chris
Old 24th April 2013, 11:10 PM   #550
RollE2k is offline RollE2k  Sweden
Acko, i have added myself to your spreadsheet. Shipping for the Clockboard was free if we had ordered the isolator/reclocker before?
Also - could you please post a BOM for the clockboard here?
Amanero Isolator/Reclocker GBHide this!Advertise here!
DQ DAC 2, BIII SE, Tube-I-Zator, Arduino, Amanero Build DQ828 Digital Line Level 94 28th December 2013 10:29 PM
FS: F5X GB chassis and all GB parts Studley Swap Meet 6 21st May 2013 12:47 PM
Amanero 384 with Kernel Streaming/Wasapi win764bit stamatiski Digital Source 9 18th November 2012 03:23 AM
Conrad Heatsinks GB in GB/EU bremen nacht Parts 1 1st February 2006 09:48 PM
