Amanero Isolator/Reclocker GB - Page 39 - diyAudio
Go Back   Home > Forums > Commercial Sector > Group Buys
Group Buys Members group buys
Old 20th February 2013, 08:40 AM   #381
nvduybom's Avatar
Can I connect from Amanero Isolator S01 to Ian FIFO board via U.FL like the attached image? .
Thank you .
File Type: jpg connect Amanero Isolator to Ian FIFO.jpg (138.2 KB, 584 views)
http://www.vnav.vn/forum
Old 20th February 2013, 09:54 AM   #382
See attached. I've circled the dots on the pcb drawing that show a through hole connection that you are able to use to take the isolated i2s from before the flipflops. If feeding the i2s to Ian's FIFO this would be the preferred way of connecting IMO. Try your best to have a separate ground connection that corresponds to each i2s signal wire to achieve GSGSGSGS signal arrangement. May mean soldering the ground wire on to the SMD pad for the flip flop.
To take from the u.fl headers you would need to use a 0ohm resistor to jumper from input to output of each of the flip flop ic positions. There is often very little point in using u.fl on the input to Ian's FIFO, on the output I would go out of my way to use u.fl between FIFO and DAC but on the input, not much point IMO with the clock speeds present on the Amanero.
There is probably a 3rd option to reclock based on the amanero clock somehow but that seems unnecessarily complex when using Ian's FIFO.
Chris
Under Construction:Ian's i2s FIFO wiki
Old 20th February 2013, 10:58 AM   #383
acko is offline acko  Australia
Default ETA
Originally Posted by acko View Post
Panelizing of board is now complete and confirmed for fabrication process. Final boards as in pic. There are now 2 boards S01 and S02 (Pot chip version). However fab guys have now advised shipment from factory in China will be delayed until 22nd Feb due the Lunar New Year holidays. So 2-3 days after that I can start shipping to you all. Hope you could hang in there for a while and sorry for any inconvenience. Let me know if anyone has concerns. In the meantime I will continue with the support.
Hi All,
I am trying to get in touch with the supplier to confirm delivery date for the boards. It has been quite a while and many have also asked me about this. Will keep pressing and as soon as I get some news I will update.
AckoDAC Project
Old 20th February 2013, 03:38 PM   #384
nvduybom's Avatar
Chris
Thank you for your help.
At the second choice, why use 0 Ohm resistor?, can I bypass between the input and output IC flip-flops? . I'm confused whether there is a difference when using the 0 Ohm resistor & bypass ?.
Regards ,
Van Duy
Old 22nd February 2013, 04:47 AM   #385
Default ETA
Hi All,
Boards are all in fab now and expected to be completed by end of next week. Will advise shipping date soon afterwards.
AckoDAC Project
Old 22nd February 2013, 05:03 AM   #386
qusp is offline qusp  Australia
qusp's Avatar
Regards ,
Van Duy
neater and more consistent impedance, but a solder bridge or piece of flat wire does fine in a pinch
Old 22nd February 2013, 05:13 AM   #387
Default Connecting before Ian's FIFO
Ordinarily, I will be worried about using a wire link but since the signals go into to Ian's FIFO and gets regenerated anyway, it does not matter much. You could also cut one end of the UFL cable assembly, strip to get the leads and dovetail to the pin pads/header just after the isolator section of the S01 board.
AckoDAC Project
Old 22nd February 2013, 05:27 AM   #388
Default Connecting after Ian's FIFO
Yes, there is no point clocking the Amanero Re-Clocker if connecting to Ian's Fifo unit as the input buffer will wipe out any clock signature. So isolation only if used this way.
But, there could be some benefits if this Re-clocker board is used after Ian's Fifo Re-clocker if the Ref clock used with the Amanero Re-clocker and the Flip-flop action is better than that on Ian's board- again all these are theoretical analysis
AckoDAC Project
Old 22nd February 2013, 06:52 PM   #389
merlin2069er's Avatar
Send a message via MSN to merlin2069er
So, how much of the board is assembled? Do I need additional parts for the isolator/reclocker?
Old 22nd February 2013, 09:10 PM   #390
MrSlim is offline MrSlim  Canada
Acko's original post indicates that it's a bare board(s) and has/will provide a BOM (casually following the thread and can't remember if he already posted it)
DQ DAC 2, BIII SE, Tube-I-Zator, Arduino, Amanero Build DQ828 Digital Line Level 94 28th December 2013 10:29 PM
FS: F5X GB chassis and all GB parts Studley Swap Meet 6 21st May 2013 12:47 PM
Amanero 384 with Kernel Streaming/Wasapi win764bit stamatiski Digital Source 9 18th November 2012 03:23 AM
Conrad Heatsinks GB in GB/EU bremen nacht Parts 1 1st February 2006 09:48 PM
Copyright 1999-2017 diyAudio
