Group Buys Members group buys
Amanero Isolator/Reclocker GB
Old 27th January 2013, 07:20 AM   #281
DQ828 is offline DQ828  Australia
DQ828's Avatar
Originally Posted by acko View Post
... BOM and schematic sometime later in the week.
Given I'm electronics challenged, I'd very much appreciate you confirming the connections to the BIIISE if possible. This is what I was thinking, see below
Also I assume it needs a separate 3.3v supply (although it seems to have 2 * 3.3v inputs ) does anyone know the best way to do this can it be taken from the BIIISE?
Old 27th January 2013, 09:31 AM   #282
acko is offline acko  Australia
Default BIIISE
If you are planning to use a BIII/BIIISE DAC with the AKL re-clocker, please note that there appears to be some sort of re-clocker already on board the BIII. Not sure what those chips are (or if they can be disabled/bypassed) but any benefit of the PotatoChips on the AKL unit is negated by the ones on the BIII. You may be better of taking the outputs from the isolator only and connect these to the BIII inputs.
Also, if you not using the on-board LDO of the AKL (not shown in the preview) then both the 3.3V inputs need to be connected to a suitable 3.3V external supply-just the way the PotChip package is.
AckoDAC Project
Old 27th January 2013, 10:15 PM   #283
Default BIII support
... Awaiting more clarification.
TPA site indicate "Integrated Re-Clocker on board" and there are ICs (U4 .. U5) that look like Flip-flops. Other think they are not but for DSD/PCM switching.
Any clearer pic on U4-U5 area would help. Sorry, I do not have any Buffs myself, they wouldn't even sell me one!
Other than that the connections are correct. 'MCLK' from AKL doing another 're-clocking' on the BIII needs further investigtion.
No similar issues with BIIs or DACs without re-clockers built-in.
3.3V supplies can be taken from DAC DVCC but if you do not wish to disturb the DAC supplies then get a separate 3.3V source for the AKL board.
More App notes are on the way to help further ....
AckoDAC Project
Old 27th January 2013, 11:52 PM   #284
SCompRacer is offline SCompRacer  United States
This help? That is an MCP23018 16-bit I/O expander at left between dipswitches. That 220 thing? I don't see the U4 & 5 you are referring to? Different board revision? This is a 1.0.1. Nothing but jumpers/connectors on other side.
Old 28th January 2013, 01:50 AM   #285
Ok thanks, BIII for the version shown earlier is fine, just direct connections to the DAC. You will get the full benefits of the AKL re-clocker.
So it is BIIISE then, this must be their latest release. IC4-IC5 on this version looks like single D-FFs to me and there is a mention of "Integrated Re-Clocker"
AckoDAC Project
Old 28th January 2013, 01:55 AM   #286
Yes, that pic is of a BIII board. I have two (dual mono). The other board is a version 1.0.2 but looks similar. A shot of the bottom of board. Right above "Thanks Brian" are the three holes under the clock. Snag the clock there?
Old 28th January 2013, 02:11 AM   #287
Yes, and use it to drive the RCK input of the Re-clocker board
AckoDAC Project
Old 28th January 2013, 02:14 AM   #288
So it is BIIISE then, this must be their latest release. IC4-IC5 on this version looks like single D-FFs .....
Possibly they are bus switches?
AckoDAC Project
Old 28th January 2013, 02:51 AM   #289
Thanks Acko. Looking at bottom of board do you think one could solder a U.Fl connector to the bottom or not enough contact for any strain on cable?
Also, with dual mono, should you connect to the master board clock? (I'm guessing yes but don't really know).
Old 28th January 2013, 03:45 AM   #290
You can try this to secure a U.FL connector this way. Alternatively, cut off one end of the u.fl cable assembly, strip a short length to get the leads and dovetail connection to the pin pads.
Yes, this should be fine. How are the signals connections to reclocker then?
AckoDAC Project
Amanero Isolator/Reclocker GBHide this!Advertise here!
DQ DAC 2, BIII SE, Tube-I-Zator, Arduino, Amanero Build DQ828 Digital Line Level 94 28th December 2013 09:29 PM
FS: F5X GB chassis and all GB parts Studley Swap Meet 6 21st May 2013 11:47 AM
Amanero 384 with Kernel Streaming/Wasapi win764bit stamatiski Digital Source 9 18th November 2012 02:23 AM
Conrad Heatsinks GB in GB/EU bremen nacht Parts 1 1st February 2006 08:48 PM
