| Group Buys Members group buys |
#11 |
Acko, Australia X1
RollE2k, Sweden X1 number9, USA X2 Klipschkid, HK, x1 randytsuch, USA X2 grufti, USA X2 kp93300, malaysia x1 Gricko,Croatia x1 NicMac, Italy x2 Running total: 13 |
#12 |
Hello,
the GB is for the bare board only. The required components are easy to find on Digikey or Mouser? Any idea of the cost of the parts? Thanks Guglielmo Italy |
#13 |
is choosing a less facetious title...
details to come, but yes it would appear so.
Acko you said something about it being for 50MHz and 100MHz only and only set for ESS, I didnt clarify, so it cant be fed any external clock circuit from the target dac? just getting that detail out cleared up before the list gets people who it wont work for. as usual looking good mate, the Amanero guys have been waiting for something like this in a proper format. i'll probably grab one too, but will see how it pans out, may just hang on and get the teflon version to go with the turboclock should go nicely with your ES9023 dac too. Last edited by qusp; 11th January 2013 at 08:02 AM. |
#14 |
Acko, Australia X1
RollE2k, Sweden X1 number9, USA X2 Klipschkid, HK, x1 randytsuch, USA X2 grufti, USA X2 kp93300, malaysia x1 Gricko,Croatia x1 NicMac, Italy x2 xtomm, Czech Republic x1 Running total: 14 Last edited by xtomm; 11th January 2013 at 10:54 AM. |
#15 |
Output connectors are U.FL only?
Thanks |
#16 |
yes
if you must, you could remove them and use the pads, which would still be better than the normal pinheader. |
#17 |
A board for the average Joe and it only accepts two oscillator frequencies ? I hope not. Useless for me if it does.
#18 | |
45.1584MHz/49.1520MHz [50MHz] OR 90.3136/98.304MHz [100MHz] When typing those numbers out often enough its easy to just approximate them to the pair of freq closest to 50MHz and 100MHz. For ES9012/8 you ideally want the [100MHz] pair of frequencies, they are not commonly available oscillator frequencies though. You'll need to read the datasheet on sync clocking to decide what oscillator frequencies suit your application. Last edited by hochopeper; 11th January 2013 at 12:02 PM. |
#19 |
#20 |
Acko, Australia X1
RollE2k, Sweden X1 number9, USA X2 Klipschkid, HK, x1 randytsuch, USA X2 grufti, USA X2 kp93300, malaysia x1 Gricko,Croatia x1 NicMac, Italy x2 xtomm, Czech Republic x1 Nikola Krivorov, Bulgaria, x2 Running total: 16 |
| FS: F5X GB chassis and all GB parts | Studley | Swap Meet | 6 | 21st May 2013 11:47 AM |
| DQ DAC 2, BIII SE, Tube-I-Zator, Arduino, Amanero Build | DQ828 | Digital Line Level | 81 | 21st April 2013 12:11 AM |
| Amanero 384 with Kernel Streaming/Wasapi win764bit | stamatiski | Digital Source | 9 | 18th November 2012 02:23 AM |
| Conrad Heatsinks GB in GB/EU | bremen nacht | Parts | 1 | 1st February 2006 08:48 PM |
