Group Buys Members group buys
Amanero Isolator/Reclocker GB
Old 7th January 2015, 01:59 PM   #1601
caad is offline caad  Denmark
SuperCape EOI:
PET-240 x 2
Chanh x2
Acko x1
Stijn001 x1
Emyeuoi x 2
Mull3t x2
Myint 67x1
bk856er x1
Supersurfer x1
RollE2k x1
Crazikid x 1
Nautibuoy x1
DQ828 x 1
Lindamar x 2
iancortez x 1
CAAD x 1
Old 7th January 2015, 02:12 PM   #1602
triodehunter is offline triodehunter  Germany
@ Acko and all
I want to use your s03 to connect a BBB (clock disabled) to an DDDac (1794a). Please let me know what pair of clocks from your suggestion will lead to the lowest phase noise / jitter. I've read your explanation on post #1081. So what frequencies / dividers / no dividers to choose? Still not sure which way to go. I want to try and get low phase noise clocks from the Andrea Mori group buy http://www.diyaudio.com/forums/digit...scillator.html. In addition: What would be the best way to connect the clocks to the S03?
Thank You
Hans
Old 7th January 2015, 02:49 PM   #1603
Greg Stewart is offline Greg Stewart  United States
Originally Posted by lindamar View Post
SuperCape EOI:
PET-240 x 2
Chanh x2
Acko x1
Stijn001 x1
Emyeuoi x 2
Mull3t x2
Myint 67x1
bk856er x1
Supersurfer x1
RollE2k x1
Crazikid x 1
Nautibuoy x1
DQ828 x 1
Lindamar x 2
iancortez x 1
CAAD x 1
Greg Stewart x 1 (but you knew that, Acko... also, maybe x 2)
Greg in Mississippi
Everything matters!
Old 7th January 2015, 03:16 PM   #1604
IanS1 is offline IanS1  United Kingdom
SuperCape EOI:
PET-240 x 2
Chanh x2
Acko x1
Stijn001 x1
Emyeuoi x 2
Mull3t x2
Myint 67x1
bk856er x1
Supersurfer x1
RollE2k x1
Crazikid x 1
Nautibuoy x1
DQ828 x 1
Lindamar x 2
iancortez x 1
CAAD x 1
IanS1 x 1
Old 7th January 2015, 08:52 PM   #1605
tods is offline tods  Germany
SuperCape EOI:
PET-240 x 2
Chanh x2
Acko x1
Stijn001 x1
Emyeuoi x 2
Mull3t x2
Myint 67x1
bk856er x1
Supersurfer x1
RollE2k x1
Crazikid x 1
Nautibuoy x1
DQ828 x 1
Lindamar x 2
iancortez x 1
CAAD x 1
IanS1 x 1
tods x 1
Old 7th January 2015, 08:55 PM   #1606
wlowes is offline wlowes  Canada
wlowes's Avatar
Originally Posted by IanS1 View Post
SuperCape EOI:
PET-240 x 2
Chanh x2
Acko x1
Stijn001 x1
Emyeuoi x 2
Mull3t x2
Myint 67x1
bk856er x1
Supersurfer x1
RollE2k x1
Crazikid x 1
Nautibuoy x1
DQ828 x 1
Lindamar x 2
iancortez x 1
CAAD x 1
IanS1 x 1
wlowes x 1
Old 8th January 2015, 04:53 AM   #1607
acko is offline acko  Australia
Originally Posted by stijn001 View Post
.....had to use the "+4+ ext_masterclk setting in the Miero driver configuration file to reverse the clock selection switch..
Excellent work! Really impressed
I am assuming that you have successfully played both 44.1 and 48k-based music
Your build looks correct, especially the position of the clocks. I am bit surprised that you needed to reverse the selection. Thought CKSEL line is low for 44.1k and goes high for 48k- based frequencies. Please check the lines again for both settings.
AckoDAC Project
Old 8th January 2015, 05:10 AM   #1608
Originally Posted by triodehunter View Post
@ Acko and all
Thank You
Hans
Yes, I have indicated 22.xx/24.xx for DACs like PCM 1794 that goes up to 192k only. So better to take advantage of the typically lower phase noise of oscillators around these frequencies. So far no actually comparisons have been made but worth a try. I am actually doing a build using 22/24 for James so will post pics soon.
No dividers required for this case.
The S03 was designed quite a while ago with board mounted oscillators mainly but you can also remove them and connect external clock directly to the clock pin pads on board. Also, you will need to tap the CKSEL lines to switch the external clocks. I am sure Andrea Mori's clocks can be connected this way.
AckoDAC Project
Old 8th January 2015, 08:10 AM   #1609
stijn001 is offline stijn001  Netherlands
stijn001's Avatar
Thanks, my new hot air rework station and some soldering paste, made the fiddly job a lot more straight forward and enjoyable. This board made me acquire some new skills.
I've played 44.1K, 96K and 192, I don't have much encoded in 48K.
I'll revisit the cksl lines and setting again, just to make sure.
Old 8th January 2015, 09:14 AM   #1610
dwjames is offline dwjames  United Kingdom
dwjames's Avatar
I understood that the pcm1794a can go up to 384k?
Amanero Isolator/Reclocker GBHide this!Advertise here!
DQ DAC 2, BIII SE, Tube-I-Zator, Arduino, Amanero Build DQ828 Digital Line Level 94 28th December 2013 09:29 PM
FS: F5X GB chassis and all GB parts Studley Swap Meet 6 21st May 2013 11:47 AM
Amanero 384 with Kernel Streaming/Wasapi win764bit stamatiski Digital Source 9 18th November 2012 02:23 AM
Conrad Heatsinks GB in GB/EU bremen nacht Parts 1 1st February 2006 08:48 PM
