Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
Group Buys Members group buys |
#1001 | ||
I think the penny may have finally dropped at this end.
If we draw a timing diagram for the Amanero/S03/9018 in full sync mode we tend to assume that the output I2S outputs from the Amanero are time aligned with MCK. Quote:
Running the 9018 fully sync removes its ability to deal with these timing differences and so we drop data ? I don't have the equipment to prove this but ... Quote:
#1002 |
Dean -
I recall seeing your post, but only came away with the notion that you had gotten it working. Realize now that you had suggested the longer path and had speculated that your solution was totally serendipitous, based on the random choice of length of ufl MCK wiring. Is the little board pictured from Ian? Would hate to think that sync mode using the SO3 is not going to work unless we can test and then fab appropriate custom-length wiring. Come to think of it, however, I don't recall anyone other than you saying that full sync works with 90/98 clocks. :-( - Pat |
#1003 | ||
I thought we already analysed this issue by taking it further with timing diagrams as show here: Quote:
@Pat, Can you try disconnecting Amanero from S03 board and see if the MCK of the Amanero is not active when connected to USB. This will indicate it is in Slave mode and ready to accept external MCK Simply measure the dc out on the MCK pin and this should be zero. If you see ~1.6 volts then MCK is active switching between 0 and 3.3V - This means the unit is not configured correctly
AckoDAC Project Last edited by acko; 12th May 2014 at 09:29 PM. |
#1004 |
When all setup (before connecting to DAC) you can also use a scope to verify the outputs (Turbo MCK, BCK) and see if they match the timing diagram shown earlier
AckoDAC Project |
#1005 | |
I suppose the new firmware - "CPLD_1080_XC12, lrclk-sclk-data reduced delay." May make a difference when NOT reclocking. I will now sit in the corner of the room for a while ![]() |
#1006 |
I will check what happens with clock signals when CPLD_1080_XC12 is flashed, because it doesn't work in slave mode.
Slave_for_1080 CPLD works, btclk_test and slave2224 works also and I'm only testing CPLDs for slave mode. Unfortunately I only have 200MHz,2Gs Rigol so my findings may not be complete (with relation to data signals as I can't see them all in the same time). |
#1007 |
I have an extra S01/S02 board from the original group buy if anyone wants it. To create synchronous mode you're going to need separate clocking unless you do P-Sync mode -- the Curryman 9023 board allows for this. Otherwise these boards are good for Async mode or just isolation. PM me if you're interested.
#1008 |
Can you clarify how the reclocking can work for 44.1 fs signal with a 100MHZ clock. Is it just that it will be close enough? If all you have is 44.1 is there another speed that is better for the reclocker using potato chips?
Thanks, Chris |
#1009 |
Banned
OT, but is it possible to fight against a jittered input sended by a non clock slaved source ?
is it possible to reclock a multiplexed input with errors and abstract clean I2S from it ? i just can't understand the difference between both sota ACKO & IAN 's work ? Sorry for the lack of technical background, also interested by an input for the futur multiple construct threads which will born around TDA1541 soon. The cheaper the better... |
#1010 | |
Hi Acko,
I quote the post of palmito because I want use this configuration with my Doede's dac but I can't make it play music. Today I complete the board with the following setup: J1 - dedicate +5V J2 - not used J3 - dedicate +5V J4 - +3.3V from the dac J6 - not used R3 - 0R R4 - not used I check all the voltage as per schematic and are all there. You have any particular advice fot help me with the troubleshooting? I attach few pictures of the board and a small adapter for the dac input. I tested the adapter with the ohmmeter and look fine. In one picture I highlight a small bridge behind the board. I don't think this should shorted ? Thanks and Regards, Enrico PS: I reconnect the i2s directly from the rpi the DAC is working fine. Quote:
Thread | Thread Starter | Forum | Replies | Last Post |
DQ DAC 2, BIII SE, Tube-I-Zator, Arduino, Amanero Build | DQ828 | Digital Line Level | 94 | 28th December 2013 09:29 PM |
FS: F5X GB chassis and all GB parts | Studley | Swap Meet | 6 | 21st May 2013 11:47 AM |
Amanero 384 with Kernel Streaming/Wasapi win764bit | stamatiski | Digital Source | 9 | 18th November 2012 02:23 AM |
Conrad Heatsinks GB in GB/EU | bremen nacht | Parts | 1 | 1st February 2006 08:48 PM |
New To Site? | Need Help? |
