Group Buys Members group buys
GB for F6 Convertible Clone boards
Old 10th July 2013, 08:03 PM   #311
dimkasta is offline dimkasta  Greece
dimkasta's Avatar
I just finished dry fitting the parts.
GB for F6 Convertible Clone boards-dim_2792-jpg
It seems that R13 and R14 are 0.5R caddocks (for IRFs), R2 is a 20R Caddock, a 9.1V zener for the led reference.
Are these correct? Also, what is the polarity mark on the Jensens? Or should I just align the letters and then the dot on the boards?
I m also a bit concerned about the zener polarity. Do they look ok?
Also about the FE, with 10mA jfets, I guess we only populate Q3A qnd Q4A right?
I also do not have an R1. Justin did you forget that one or it would not be included in the GB?
Thanks again for a nice package.
Too many projects... so little time...
Old 10th July 2013, 08:20 PM   #312
bk856er is online now bk856er  United States
bk856er's Avatar
Is your Q4A inserted correctly??
BK
Old 10th July 2013, 08:22 PM   #313
dimkasta's Avatar
BK
Good catch
THANKS A LOT!!
Old 10th July 2013, 09:06 PM   #314
buzzforb is offline buzzforb  United States
buzzforb's Avatar
Everything is correct exept for Jfet. the pinout on the Jensen will help locate it properly. Pin 1 is the only one with a smaller offset. You should have two R1's.
...Shape the sound , Man!
Old 10th July 2013, 11:34 PM   #315
bk856er's Avatar
Also see post #41 for link to Jensen pdf, and post #144 for a nice pic of proper daughter card orientation.
Some good info in Tea's F6 blog about FE considerations. My understanding is you're good to go with one pair 10mA jfet and R11/R12 as supplied by buzz.
BK
Old 10th July 2013, 11:39 PM   #316
dimkasta's Avatar
Justin's mention of the offset makes perfect sense.
Basically you cannot solder the Jensen on the daughterboard in a wrong way unless you force it and bend the pins significantly.
You just have to be careful to follow the dots on the boards to attach the daughterboard
Old 27th July 2013, 08:31 AM   #317
slr 5000 is offline slr 5000  Australia
Hi all
got the parts thanks Buzz!!
few questions
I,m building the f6 buffered using the original schematic on the firstwatt site
and I need to clarify a few things
1, the f6 buffered schematic above does not have r11/12 I suspect these are for jft degeneration ,do I use them ? if so what goes there (I have 4 x 10r left from buzz,s kit after populating everything as per the above schematic )
2, what way do the led install ,one of the solder pads is square the other is round(teas boards)
3, what are the diodes for in the kit ,the f6 buffered schematic does not show any
4, do I have to install p3 /p4, I just want to build as per nelsons original circuit which does not use these
rgds Sheafer
Old 27th July 2013, 12:21 PM   #318
Ryssen is offline Ryssen  Sweden
Ryssen's Avatar
Could you take a closer pic of those zeners,couse I got a resistor there instead,or maybee that will work as well?
Regards Åke
Old 27th July 2013, 12:30 PM   #319
buzzforb's Avatar
The Zener's were included for those folks who would be using the IRF outputs. It give you a larger voltage to divide down with the pot for the gate of the mosfet.
The Led's have one long leg. That leg is the anode of the LED.
You will have to post the schematic you are talking about for me to know how to advise. There were several put out in the article
Old 27th July 2013, 01:15 PM   #320
HI Buzz
I just noticed the 'f6 variable 2nd' schematic which matches the board and parts so I guess that is what I will put together
re the zeners , im using r100 semis so does that mean im just to install both led,s ?
Sheafer
GB for F6 Convertible Clone boardsHide this!Advertise here!
GB for F5T Convertible amplifier boards Tea-Bag Group Buys 127 13th July 2014 07:48 PM
F5 clone boards (inc PSU boards) Tazzz Swap Meet 39 7th June 2014 08:02 AM
Gb: Rectifier boards cviller Group Buys 58 24th October 2010 05:52 PM
GB - F5 Clone suds Group Buys 3 23rd August 2010 02:03 PM
B1 Boards V. Mini GB rhysh Group Buys 257 10th June 2010 09:29 AM
