Group Buys Members group buys
SV Oscillator PCB group buy
Old 28th November 2012, 08:09 PM   #51
dirkwright is offline dirkwright  United States
dirkwright's Avatar
Originally Posted by AKN View Post
Yes, but if the primaries differ slightly (in real life). Can you get the same performance by taking feedback from just one winding? Me thinks that both windings should be included.
Performance is actually not much better with the Jung circuit shown in the document I cited earlier. This circuit has the 2nd harmonic at only about -97dB down @ 20Hz, 1.4 Vrms output. Transformer has permalloy core, 300 turns, DC resistance of 18 ohms per winding, etc.
Old 28th November 2012, 08:18 PM   #52
AKN is offline AKN  Sweden
No snake oil
AKN's Avatar
SV Oscillator PCB group buy Send a message via MSN to AKN
Have you tried to adjust gain in lower OP-amp as in circuit by Ljung?
/ Anders
Old 28th November 2012, 08:41 PM   #53
dirkwright's Avatar
Yes, I varied R5 by +/- 100 ohms with much worse THD each way.
While these are probably the best that can be had from a line level output transformer, we're still talking about a second harmonic down about 90dB or so. Since I don't have all of the particulars of the transformer, I have to guess at some of the parameters. The Jung circuit is slightly better than the one I originally used. I'm still twiddling with it.
Old 28th November 2012, 09:20 PM   #54
No snake oil
AKN's Avatar
Ok, I hope the distortion creeps down further and further...
/ Anders
Old 28th November 2012, 09:26 PM   #55
dirkwright's Avatar
OK, now we are getting somewhere. I guess the devil is in the details. I have the transformer windings in parallel, BTW, just as before. THD is 5x10^-5%, 2nd harmonic is down -130dB from the fundamental @ 20Hz. Performance is just as good @ 1kHz. Adding buffers doesn't really help. So, thanks for the suggestions. Noise is extremely low as well.This one is worth building.
Old 28th November 2012, 09:34 PM   #56
No snake oil
AKN's Avatar
Great!
How do different secondary loading influence distortion, any need to reset null?
/ Anders
Old 28th November 2012, 10:11 PM   #57
dirkwright's Avatar
Great!
I don't know. I doubt it matters.
Old 28th November 2012, 10:31 PM   #58
No snake oil
AKN's Avatar
Maybe a misunderstanding, i.e. I wasn't clear? I thought if you had your simulation up and running it would be easy to change transformer secondary load (R6).
I'll be implementing transformer output as well. Really nice to have galvanic separation from the noisy PC ground that jerks around with high frequency.
/ Anders
Old 28th November 2012, 10:59 PM   #59
dirkwright's Avatar
Oh, I understand you mean the load resistor. It shouldn't matter, but I don't really know.
I recommend a transformer with a high nickel core (80%). They simulate (and in real life perform) much better than anything else.
Old 29th November 2012, 11:18 AM   #60
No snake oil
AKN's Avatar
Doh, I get it now. Needed some time (sleep) to understand.
/ Anders
SV Oscillator PCB group buyHide this!Advertise here!
LT AN67 Ultralow THD 10kHz sine oscillator group buy. Frex Group Buys 63 6th March 2016 08:36 AM
PCB Group buy go77306 Group Buys 8 8th March 2012 02:58 AM
Copyright ©1999-2017 diyAudio
