ES9023 / WM8804 S/PDIF "Subbu DAC V3" GB Interest - Page 66 - diyAudio
Go Back   Home > Forums > Commercial Sector > Group Buys
Group Buys Members group buys
Old 8th April 2013, 06:07 PM   #651
kumori is offline kumori  Europe
Originally Posted by voxxonline View Post
Plus I am getting JG Filter buffer, has anyone tried it with 9023 and directly into amp via pot or something similar, bypassing passive or active amp all together..?
I asked myself the same thing. I assume the 9023 can drive a 20k to 100k pot, so it would probably make sense to put the JG-buffer behind the pot. It will present a low impedance source to the poweramp then.
Old 8th April 2013, 06:38 PM   #652
massimo is offline massimo  Italy
AFAIK the buffer has been calculated considering the low o/p impedance of the DAC (240ohm) and the influence of the lo pass filter created by the 4.7nF cap suggested in the application note. Are U sure that putting a pot in between you will keep the same conditions?
Old 8th April 2013, 07:08 PM   #653
Oh, I was not aware of that. Than it shall not be done.
But thanks, good to know.
Old 8th April 2013, 10:41 PM   #654
hajj is offline hajj  Lebanon
hajj's Avatar
Added myself to the list.
Thanks guy for putting this together.
Just the project I needed, whenever it's ready...
Old 9th April 2013, 10:53 AM   #655
billyk is offline billyk  United States
billyk's Avatar
I will be putting one of these in my pre that is still in the design stage. It will have some kind of buffer, JFet ala B1, or maybe with a little gain like a JISBOS. Will be using lightspeed type of attenuator for volume control.
Old 9th April 2013, 05:36 PM   #656
I am really interested in the setups all you are going to bild with it.
Especially the device between the source and the Subbu v3 DAC would be interesting.
I am looking to build USB DAC with a WaveIO XMOS Based USB->SPDIF/IS and this Subbu DAC v3... I think this will be a really good setup!
Greetings from Germany!
Ron
Old 10th April 2013, 03:19 AM   #657
grufti is offline grufti  United States
grufti's Avatar
My personal favorite USB->I2S is the Amanero. No SPDIF in that case, but the thing is tiny, cheap via the ongoing repeat group buys, functional, and well supported. I've used it with V2.6 with good results.
Old 13th April 2013, 08:42 PM   #658
GaryB is offline GaryB  United States
It wouldn't be that hard to do. Here's what I suggest. I've attached a schematic for the JG filter. In the schematic, you see R1 = 18.9K in the latest version. One could use a 20K volume control and put a 340K resistor in parallel with the pot, which gives ~18.9K resistance. Then hook up R2 to the wiper of the volume control and you have now integrated a volume control into the filter/buffer.
---Gary
Old 13th April 2013, 10:11 PM   #659
---Gary
Im not sure that is that easy. At the time I wrote about the pot before the buffer, I thought "buffer" = "high input impedance/low output impedance" without looking at the schematic. But here the LC input filter seems indeed to be tailored for a specific application.
Replacing R1 with a pot+parallel R, will change the shunt R/series R in the schematic a lot, depending on the pot position.
Old 13th April 2013, 11:06 PM   #660
I think it actually does work. The suggestion I made loads the pot with the high impedance node of the buffer part of the circuit, so the filter works just fine. The pot becomes the load for the L-R filter and it's value doesn't change because the impedance of the buffer is high. Putting the volume pot on the other side of the inductor, i.e. between the DAC and filter/buffer board would not work.
---Gary
ES9023 / WM8804 S/PDIF DAC Group Buy unixdeveloper Group Buys 683 16th July 2015 07:33 PM
Case for "ES9023 / WM8804 S/PDIF DAC Group Buy" rvrazvan Digital Source 3 27th July 2014 08:37 AM
Power Supply PCB for ES9023 / WM8804 S/PDIF DAC Group Buy unixdeveloper Group Buys 145 29th July 2013 12:55 PM
WTB ES9023 DAC PCB by Subbu & Jean-Paul Reima Swap Meet 5 18th December 2012 07:39 PM
ES9023 / WM8804 S/PDIF DAC Parts GB EU Only korben69 Group Buys 187 10th October 2012 11:25 AM
Copyright 1999-2017 diyAudio
