ES9023 / WM8804 S/PDIF "Subbu DAC V3" GB Interest - Page 65 - diyAudio
Go Back   Home > Forums > Commercial Sector > Group Buys
Group Buys Members group buys
Old 4th April 2013, 07:22 AM   #641
atupi is offline atupi  Romania
Sounds good, waiting for JP's updates.
Rega RP-1/Simplistic RIAA by Salas/ DCB1 clone/ MyRef Fremen Edition/FC-100/ XTZ 99.26 MkII speakers
Old 4th April 2013, 07:50 AM   #642
Hi Subbu
Nice to read you've shipped V3 Beta PCB to builders.
I may say RC, Realease Candidate, vs Beta.
You say "Sounds pretty good", could you elaborate ?
Did you use Jean Paul LM723 based PSU too ?
I was hoping to read much more from you after such a long time
From what I've read about V3 DAC, I can say :
1 - V3 DAC uses 0805 & 1210 parts, no smaller 0603 type parts to deal with
2 - 4 ultra low noise LDO (3.3V & 3.6V) as used in improved V2.6
3 - U.FL connectors pads added for I2S input
4 - More left space for non SMD caps alternative : Polymer/Electrolytic/Film
5 - Circuit Design & PCB traces optimized by "Moderator Emeritus" (invaluable input)
6 - SE Version is almost complete, final testing in progress.
Well, the end of waiting is close to ending.
More to come with pics and details, hope it will be soon now
Phil
Old 4th April 2013, 08:22 AM   #643
massimo is offline massimo  Italy
For the v.3 BOM you might consider a different (and possibly better) LDO reg such as this: http://www.ti.com/lit/ds/symlink/lp2985-n.pdf now available in SOT23 P2P compatible package and 3.6V.
Being a low Zout reg (0.3ohm), low ESR caps can be used at its o/p (MLCC vs Tantalum). Noise 30uV (300Hz-50kHz). Slightly worse PSRR, but we can rely on a low noise pre-reg
Old 4th April 2013, 09:01 AM   #644
diyAudio Moderator Emeritus
jean-paul's Avatar
LP2985 is not an improvement.
It's only audio. Member of the non modular PCB design committee
Old 4th April 2013, 12:04 PM   #645
syklab is offline syklab  Hong Kong
May be the TI LP5907, spec looks ok but no 3.6V.
Old 4th April 2013, 12:27 PM   #646
Turbon is offline Turbon  Sweden
Turbon's Avatar
OK, I'm in. Exciting to compare this to other implementatins of the 9023...
Old 8th April 2013, 10:31 AM   #647
billyk is offline billyk  United States
billyk's Avatar
Bump for some news!
Any more built? What are the builders general impressions?
Looking forward to adding this to my set-up!
Old 8th April 2013, 10:37 AM   #648
voxxonline's Avatar
Send a message via Skype™ to voxxonline
Patience is the key...
This dac is like a good wine - the longer you wait the better it gets ...
How to find time to finish my projects ?
Old 8th April 2013, 03:13 PM   #649
And there's also nothing wrong with a good vinegar
Old 8th April 2013, 03:30 PM   #650
voxxonline's Avatar
TBH I would like to know if any bom has been proposed, as I am on hold for my other parts due to Mouser minimum quantities policy. Will do everything in one go.
Plus I am getting JG Filter buffer, has anyone tried it with 9023 and directly into amp via pot or something similar, bypassing passive or active amp all together..?
ES9023 / WM8804 S/PDIF DAC Group Buy unixdeveloper Group Buys 683 16th July 2015 07:33 PM
Case for "ES9023 / WM8804 S/PDIF DAC Group Buy" rvrazvan Digital Source 3 27th July 2014 08:37 AM
Power Supply PCB for ES9023 / WM8804 S/PDIF DAC Group Buy unixdeveloper Group Buys 145 29th July 2013 12:55 PM
WTB ES9023 DAC PCB by Subbu & Jean-Paul Reima Swap Meet 5 18th December 2012 07:39 PM
ES9023 / WM8804 S/PDIF DAC Parts GB EU Only korben69 Group Buys 187 10th October 2012 11:25 AM
Copyright 1999-2017 diyAudio
