Go Back   Home > Forums > Commercial Sector > Group Buys
Group Buys Members group buys
Old 7th March 2013, 04:39 PM   #621
Thanks for the update.. Can not wait to "listen" to them. Man. would really want to come over to "test" the board! ^^
But from Hamburg its a "long" way!
Also waiting for the new WaveIO Board. My SymAsym Amp and my Speakers are almost finished.
"Nuttin over good sound and music! "
Old 13th March 2013, 11:21 AM   #622
Hi all,
this is my first post but I read the forum for a long time
I've just added my name in the spreadsheet, I'm scared of soldering the ES9023 but I'm very exciting too
Old 13th March 2013, 11:43 AM   #623
RollE2k is online now RollE2k  Sweden
I removed myself, since i will wait for a BAL version - and ain't in hurry for this.
Old 13th March 2013, 11:26 PM   #624
Phil,
When the single ended version is available can it be purchased and later the balanced version board be added to it?
Bill
Old 14th March 2013, 11:03 AM   #625
iskwon is offline iskwon  South Korea
iskwon's Avatar
Default BG entering
Jean-Paul, thanks for hard work.
I just found this GB and entered 4 SE and 2 BAL.
I will be looking forward to seeing your masterpiece.
Old 18th March 2013, 04:37 PM   #626
Originally Posted by wirewiggler View Post
Phil,
Bill
Hi Bill and All
I think so but can't confirm it to be absolutely "true" right now.
BAL version design isn't finalized yet.
In previous V2.6, SE DAC could be upgraded to BAL version.
A second DAC/PCB is added, specially populated to achieve BAL goal.
Hope this help
Phil
Old 18th March 2013, 07:32 PM   #627
Default Attenuator on output
I think it has been said in the thread that this DAC can be used with its outputs direct into a power amp, with one of the advantages of this DAC being the built in driver stage.
I would like to install one into a power amp with a stepped attenuator between DAC output and power amp input - to control the analogue volume without the need for a pre/buffer. Could anyone clarify if this would be a suitable set-up? and if so, is there a particular impedance for an attenuator that would suit the DAC output best? Thanks. (In my situation amp input impedance is 33kohm).
Old 21st March 2013, 05:37 PM   #628
Send a message via Yahoo to lil' knight
Is the forthcoming BAL version has 2x es9023 on 1 board or we have to use 2 separate boards?
Old 21st March 2013, 05:40 PM   #629
diyAudio Moderator Emeritus
jean-paul's Avatar
We are still waiting for the SE test PCBs which take a lot of time to produce apparently. The BAL version is being designed by Subbu. So I don't know what it will be although I have an idea. Maybe if I offer my help I can take a peek ...
It's only audio
Old 24th March 2013, 06:15 PM   #630
thanks for the update JP! maybe you guys should consider subbu dac v4 as a kickstarter project. A little extra funding to help you guys test diff configurations. And anything left over could be used for v5
ES9023 / WM8804 S/PDIF DAC Group Buy unixdeveloper Group Buys 659 16th May 2013 02:55 AM
Power Supply PCB for ES9023 / WM8804 S/PDIF DAC Group Buy unixdeveloper Group Buys 141 10th May 2013 09:23 PM
WTB ES9023 DAC PCB by Subbu & Jean-Paul Reima Swap Meet 5 18th December 2012 07:39 PM
ES9023 / WM8804 S/PDIF DAC Parts GB EU Only korben69 Group Buys 187 10th October 2012 11:25 AM
Case for "ES9023 / WM8804 S/PDIF DAC Group Buy" rvrazvan Digital Source 2 11th June 2012 08:38 AM
Copyright ©1999-2013 diyAudio
