| Group Buys Members group buys |
#531 |
OK - Good luck.
BTW - Could you be soldering a bit to hot? I try to do most work at 330C. Just a thought... Ken |
#532 |
hm... 25 w soldering iron. not sure about the temperature
#533 | |
#534 |
Here is a picture of part of pcb.
#535 |
That's hard to see exactly what's happening there, but the darkness/dullness of the other solder points suggests you may not be using the best solder. Are you using liquid or paste flux in your work? Is there still copper under the grey on those open pads?
Bob M. "Arrange Whatever Pieces Come Your Way." |
#536 |
I must admit I stopped all soldering works because of this BAD solder. I ll get suggested rosin 37/63 solder and continue.
I do flux. There is a thick copper pad in place , sort of copper bridge from wiper to the right pad. I should listen to advise and buy good solder right away
#537 |
You can use rubbing alcohol or fingernail polish remover with an old toothbrush to clean things up before your next attempt. The investment in a good liquid flux used in addition to the flux that may be in the solder is well worth the cost. It cleans up easily as suggested above.
Mine aren't perfect but the end result should be closer to shiny bright. I like this shape for scraping pads when necessary. Radio Shack has a 62/36/2 silver solder that is decent and doesn't cost much. Good Luck !
Bob M. "Arrange Whatever Pieces Come Your Way." Last edited by bcmbob; 22nd January 2013 at 02:18 PM. |
#539 |
ChipQuick in the syringe is my favorite. Other brands are available but the syringe is very useful. My second choice is liquid with a brush.
Whatever you use don't be afraid to use more rather than less. It all cleans up well. My work looks horrible till I do the final clean up with alcohol/toothbrush. ![]() BTW, Dow Bathroom Cleaner (Scrubbing Bubbles) works great to remove any flux residue after the alcohol pass.
Bob M. "Arrange Whatever Pieces Come Your Way." Last edited by bcmbob; 22nd January 2013 at 02:33 PM. |
#540 |
Kester-951 is also good and no cleaning needed.
| ES9023 / WM8804 S/PDIF DAC Group Buy | unixdeveloper | Group Buys | 665 | 13th June 2013 10:30 PM |
| Power Supply PCB for ES9023 / WM8804 S/PDIF DAC Group Buy | unixdeveloper | Group Buys | 144 | 27th May 2013 08:51 AM |
| WTB ES9023 DAC PCB by Subbu & Jean-Paul | Reima | Swap Meet | 5 | 18th December 2012 07:39 PM |
| ES9023 / WM8804 S/PDIF DAC Parts GB EU Only | korben69 | Group Buys | 187 | 10th October 2012 11:25 AM |
| Case for "ES9023 / WM8804 S/PDIF DAC Group Buy" | rvrazvan | Digital Source | 2 | 11th June 2012 08:38 AM |
