Go Back   Home > Forums > Commercial Sector > Group Buys
Group Buys Members group buys
Old 22nd January 2013, 11:41 AM   #521
houghtkj's Avatar
Personally, I use a 2mm chisel bit for ALL my SMD work and have had no problems. If you use too fine a tip, it's very difficult to keep the tip tinned which means it's harder to get a thermal contact with the part.
So I would go for a B005360 bit - And don't forget the solder wick!
Old 22nd January 2013, 11:51 AM   #522
Send a message via Skype™ to voxxonline
I think 5360 is that I have now
</Addiction> My project map / slowing down for summer
Old 22nd January 2013, 11:51 AM   #523
BTW what about solder wick (I have one ) ?
Old 22nd January 2013, 12:33 PM   #524
houghtkj's Avatar
Just need to make sure the tip is clean and well tinned - I use a damp sponge and that course wire wool stuff.
Life just isn't complete without solder wick - I use 2 widths for SMD - 1.5mm and 2.5mm. When soldering something like the WM8804, I find the best method is to flood solder the pins, then wick off the excess, which should also get rid of any bridges. Be VERY careful not to let the wick "freeze" to the chip pins or pads - Just keep the solder molten and the wick moving.
You will almost certainly want some additional flux - I use a gel flux and apply it with a syringe - Use plenty because the flux in cored solder burns off quickly.
Good luck - Ken
Old 22nd January 2013, 12:45 PM   #525
Thank you.
Off topic: been de soldering trimming pot , and somehow ring on pcb around wiper is not visible any more.
I have checked continuity between wiper and adjacent pole and it is there (as on the rest of pots) and not sure is pcb damaged or continuity is there for a reason
Any ideas ?
P.S. Hate desoldering ...
Old 22nd January 2013, 12:49 PM   #526
bcmbob is offline bcmbob  United States
I like the copper Chore Boy as it is a bit coarser an is well - copper
They are available at most grocery stores and I just stuff them in an old spray paint can top.
Bob M.
"Arrange Whatever Pieces Come Your Way."
Old 22nd January 2013, 12:54 PM   #527
Good idea this scrubber bcmbob
Old 22nd January 2013, 01:06 PM   #528
houghtkj's Avatar
Hi Ivan, Bit of a problem there - Is the PCB double sided? And which pad has lifted - Solder side or component side? If it's the component side pad thats lifted, you should be OK assuming the through plating is good. If it's the solder side, you will need to scrape and tin the trace and piece out with a short bit of wire.
Hope that makes sense.
Ken
Old 22nd January 2013, 01:10 PM   #529
It is Uriah's Lighter note. It is the solder side. No pads were lifted its just the black ring surrounding wiper got missing.
I ll try to scrap , otherwise order replacement pcb. Only few components been soldered so damage is not that big... the learning curve !
Old 22nd January 2013, 01:14 PM   #530
Can you post a picture?
Bob M.
ES9023 / WM8804 S/PDIF DAC Group Buy unixdeveloper Group Buys 659 16th May 2013 02:55 AM
Power Supply PCB for ES9023 / WM8804 S/PDIF DAC Group Buy unixdeveloper Group Buys 141 10th May 2013 09:23 PM
WTB ES9023 DAC PCB by Subbu & Jean-Paul Reima Swap Meet 5 18th December 2012 07:39 PM
ES9023 / WM8804 S/PDIF DAC Parts GB EU Only korben69 Group Buys 187 10th October 2012 11:25 AM
Case for "ES9023 / WM8804 S/PDIF DAC Group Buy" rvrazvan Digital Source 2 11th June 2012 08:38 AM
Copyright ©1999-2013 diyAudio
