Go Back   Home > Forums > Commercial Sector > Group Buys
Group Buys Members group buys
Old 18th October 2012, 08:39 PM   #211
knorst is online now knorst  Germany
added one se-kit on the spreadsheet.
thanks
Old 18th October 2012, 10:26 PM   #212
Hi all
What can I say ? Impressed, yes really, this thread is really Alive due to your inputs and tips. That's DIYAudio spirit, sharing and caring
Many thanks to all of you
We've crossed 380 PCB units !!! Unexpected, the challenge initiated by "Moderator Emeritus" has been exceeded
As previously announced, the GB was supposed to be closed today.
So, why closing today ? Let's say it's still open, until the 26th.
Three majors reasons :
1° - It gives late comers some extra time to place their orders.
2° - Only 18 PCB to go and we'll reach 400 units !
3° - October 26th is my birthday, I'll be proud to close this GB as it's a special day to me
I'm convinced that Jean-Paul & Subbu will give some informations about the final design they've cooked for us before the 26th.
Can't expect what "Master Chaos" AKA Jean-Paul comment will be...
More to come...
Old 18th October 2012, 10:38 PM   #213
diyAudio Moderator Emeritus
jean-paul's Avatar
Incredible. The number keeps getting higher and no one except Subbu And I knows what the design will be. Scary.... Earlier on I told Subbu that demand could very well be 500 pieces of which I later on thought I had exaggerated but now it seems the 500 number was not so exaggerated at all.
We are still in design phase. Despite earlier comments the boards seems to become slightly larger with all the in and outputs aligned at one side except for the power supply connector. So finally SPDIF and L + R are all at the backside of the case. Decoupling already was good but we tried to improve it slightly by adding coils and caps. Different sizes output filter caps can be used.
I am working from dusk till dawn in my new home (moving houses/emigration) so I try to arrange time in 5 minute blocks but we will manage a V3.
We won't let you down. Hey the simplest solution would have been a rerun of V2.6 but that is still possible if V3 does not perform as we wish.
It's only audio
Old 19th October 2012, 05:30 AM   #214
Send a message via Skype™ to voxxonline
As I have more time, I will read into possibility of separating channels and running dac in "dual mono" mode (correct ? )
If members of GB can give some thoughts would really appreciate it.
</Addiction> My project map / slowing down for summer
Old 19th October 2012, 01:45 PM   #215
6speed is offline 6speed  United States
As I understand, in DAC terms, that normally means a "balanced DAC". If you are interested in going that route you should check your order to ensure it's entered as a balanced kit.
Old 19th October 2012, 02:23 PM   #216
tubo is offline tubo  Philippines
Pls count me in for 2 dac boards, 2 es9023, 2 psu boards, 2 SE kit, 2 psu kit. Thank you very much
Old 19th October 2012, 03:20 PM   #217
You're right
A BAL DAC is a "Dual Mono" using 2 PCB & 2 ES9023, one for each chanel.
Don't forget that the Output is Balanced (XLR).
If you want to go SE (RCA) and "Dual Mono", you have to convert Balanced signals to Single Ended using some BAL/Unbalanced transformer/converters/adapter.
One PSU is OK to fed a BAL DAC.
Hope this helps
Old 19th October 2012, 04:31 PM   #218
JEAN-PAUL
HI, AM I TOO LATE FOR THE GROUP BUY? IT SEEMS THAT IT HAD ALREADY CLOSED YESTERDAY.
HOPING ITS STILL OPEN..
THANK YOU
Old 19th October 2012, 04:33 PM   #219
Does anybody know benefits of dividing channels and dedicating individual dac ?
Old 19th October 2012, 05:34 PM   #220
bcmbob is offline bcmbob  United States
There is much on a google search similar to this article.
And a conversation.
Personally, I own four devices suitable for home studio/semi pro recording that all have balanced outputs. IMHO, it is a different ballgame and I prefer the unbalanced format for high end listening. In my experience the advantages of balanced are most effective when long cables and high potential for inteference are present.
Bob M.
"Arrange Whatever Pieces Come Your Way."
ES9023 / WM8804 S/PDIF DAC Group Buy unixdeveloper Group Buys 659 16th May 2013 02:55 AM
Power Supply PCB for ES9023 / WM8804 S/PDIF DAC Group Buy unixdeveloper Group Buys 141 10th May 2013 09:23 PM
WTB ES9023 DAC PCB by Subbu & Jean-Paul Reima Swap Meet 5 18th December 2012 07:39 PM
ES9023 / WM8804 S/PDIF DAC Parts GB EU Only korben69 Group Buys 187 10th October 2012 11:25 AM
Case for "ES9023 / WM8804 S/PDIF DAC Group Buy" rvrazvan Digital Source 2 11th June 2012 08:38 AM
Copyright ©1999-2013 diyAudio
