Group Buys Members group buys
ES9023 / WM8804 S/PDIF "Subbu DAC V3" GB Interest
Old 22nd January 2013, 05:12 PM   #541
houghtkj is offline houghtkj  United Kingdom
houghtkj's Avatar
If you are in the UK and you aren't doing a load of SMD work, I suggest you get this from Rapid: SMD rework jelly and solder pack
The flux will last ages and the solder is 62% tin, 2% silver, 36% lead.
Unless you have masochistic tendencies, dont use lead free solder, you wont go far wrong with 80/20 or 63/37 solder 26SWG.
I also suggest getting a temperature controlled iron of about 50W - The one you have is a bit low powered at 25W (lower power means that the iron struggles to maintain tip temperature, so requires more time to do the job). Take a look at this from Maplin: 48W LCD Display Solder Station : Temperature Controlled Irons & Solder Stations : Maplin Electronics
Ken
Old 22nd January 2013, 10:36 PM   #542
JJGB is offline JJGB  Finland
Spreadsheet Updated, 1 Bal kit.
Old 24th January 2013, 02:44 PM   #543
BackinBlack is offline BackinBlack  England
BackinBlack's Avatar
Just a quick comment. I notice that Uriah recommends not to use silver loaded solder for the lighter note, in particular for the LED optocoupler a the cadmium sulphide LDR is easily damaged by excess heat. I'm still using good old (very old!!) Ersin multicore, essential to clean excess flux from completed joints after though. There are still available lead/tin solders, such as Autosol from Rapid, good for most purposes.
Ian.
Old 25th January 2013, 07:36 PM   #544
Witty is offline Witty  Hong Kong
Originally Posted by jean-paul View Post
All I can say is that an SE version seems ready for production of prototypes and Subbu is grinding his teeth on the BAL version.
I am wondering how true balanced output (i.e. +ve part out of one channel and -ve signal out of the other) is obtained here. From limited information ES9023 has no +ve and -ve outputs (only SE L&R output) so using two ES9023s only double the maximum output current. Unless the I2S is divided into +ve and -ve stream before entering ES9023.
Old 25th January 2013, 09:36 PM   #545
Wiggly is offline Wiggly  United Kingdom
Put myself down for an SE kit, thanks for for all the hard work you guys are putting in to make this happen.
Old 26th January 2013, 10:19 AM   #546
samoloko is offline samoloko  Bulgaria
I bought v2.6
would you please explain benefits of v3
Old 26th January 2013, 11:34 AM   #547
pilli is offline pilli  France
Originally Posted by samoloko View Post
I bought v2.6
...for one thing, v3 group buy is sttill open, so that's a trivial benefit for those like me, who saw this project "a bit late"...
And with some improvements that are hinted at the beginning of this thread.
Old 26th January 2013, 02:58 PM   #548
MrSlim is offline MrSlim  Canada
I bought v2.6
isn't it obvious... its at LEAST .4 better.. .
I was out of the loop during the 2.6 group buy so this is my chance to get in on the fun.. Until there is a final completed product to compare to 2.6, it's anyone's guess how much better it will be (if it would even be noticeable by TinEars like me...) I'll at least be able to compare it to my existing DAC's
Old 27th January 2013, 12:06 AM   #549
jean-paul is offline jean-paul  Netherlands
diyAudio Moderator Emeritus
jean-paul's Avatar
I bought v2.6
None if you are happy with 2.6.
It's only audio. Member of the non modular PCB design committee
Old 27th January 2013, 06:19 AM   #550
henryve is offline henryve  South Africa
henryve's Avatar
Added to spreadsheet. What the hell, will be my first DAC. Bought or DIY.
ES9023 / WM8804 S/PDIF "Subbu DAC V3" GB InterestHide this!Advertise here!
ES9023 / WM8804 S/PDIF DAC Group Buy unixdeveloper Group Buys 690 14th January 2018 08:46 AM
Case for "ES9023 / WM8804 S/PDIF DAC Group Buy" rvrazvan Digital Source 3 27th July 2014 09:37 AM
Power Supply PCB for ES9023 / WM8804 S/PDIF DAC Group Buy unixdeveloper Group Buys 145 29th July 2013 01:55 PM
WTB ES9023 DAC PCB by Subbu & Jean-Paul Reima Swap Meet 5 18th December 2012 08:39 PM
ES9023 / WM8804 S/PDIF DAC Parts GB EU Only korben69 Group Buys 187 10th October 2012 12:25 PM
