Power Supply PCB for ES9023 / WM8804 S/PDIF DAC Group Buy - Page 14 - diyAudio
Go Back   Home > Forums > Commercial Sector > Group Buys
Group Buys Members group buys
Old 19th March 2013, 09:36 PM   #131
diyAudio Moderator Emeritus
jean-paul's Avatar
Just looked up the Mytek. Boy what fun it is to know our Subbu DAC V2.6 is better than a DSD DAC (with more advanced Sabre chip) that retails for 1695 US $ !
"Plain affordable and reliable stuff designed to sound good", it was like that in the golden age of HiFi and it still is possible in 2013. I am as curious as some of you how the PCB's for V3 turn out. We are waiting for those now.
Some news: the PSU PCB will be changed to a new revision. Details will follow later.
It's only audio. Member of the non modular PCB design committee
Old 19th March 2013, 10:56 PM   #132
palmito is offline palmito  United States
palmito's Avatar
Quoting Flounder in Animal House: "oohh boy, this is great!"...
Old 20th March 2013, 12:01 AM   #133
GaryB is offline GaryB  United States
ES9018 is not a fair comparison (which does not prevent from comparing of course) but still... the Subbu DAC probably costs less than one of the Sowthers... How much better is the ES9018 ? Simply significantly better or slightly better like let's say 5 % ? And how do prices compare so what did the ES9018 DAC cost to build if I may ask ?
The Bufffalo III + SPDIF board + shunt power supply + power transformer is about $500. Add on top of that the output transformers and the power supply and output buffer. I got the output transformers in trade so they didn't cost me much. But to build this from all new parts would easily cost between $700 and $800 - maybe more if I accurately counted everything. The chassis is homemade out of plywood and oak . I can hear you reminding me about lack of shielding already.
Even so, it does sound significantly better than the Subbu DAC + JG filter/buffer, which in my opinion is also a good step up from just the Subbu DAC. Of course, tweaking the JG filter/buffer has closed the gap - it remains to be seen how much. I'll report back at a future date.
BTW shielding is not a case of listening. It must be shielded as it contains a 50 MHz XO. You can listen to different caps and such but electronics with high frequency components just must be shielded.
Regarding the question of shielding, it's not that I don't understand your point. I completely understand. I've been a ham operator since I was 12 years old and I've got degrees in EE. It's just that I'm not sure that I agree. The wavelength of a 50Mhz signal is 6 meters. I just don't think we'll be seeing a lot of radiation from the small traces on the boards. The much more likely source of 50Mhz noise is through the power supply and ground lines. And shielding will not have much impact on this at all. Assuming that you and Subbu have done a good job laying out the board and dealing with ground then I think things probably work fine without shielding. Of course, I'm always open to new information, so if you've measured significant changes in 50Mhz clock noise coming out of the DAC with shielding then I'm willing to change my opinion. In fact, I've got a good 100Mhz scope so I may poke around and see what I can measure
---Gary
Old 20th March 2013, 06:45 AM   #134
jean-paul's Avatar
Hi there should be a difference with such a lot of engineering, cost and a chip that is the ES9023 big brother. It would have been truly unbelievable if the Subbu V2.6 would have been better than a full grown well designed ES9018 DAC. That is why I am surprised that the Mytek sounds less good. That one has a good reputation.
Regarding the shielding: I had problems with the very first version V0 which is why the coils and later the beads have been added. I clearly measured 50 MHz on the supply lines. Also the open PCB (with long wiring as it was a test example) was sensitive to a cell phone that was laying on the desk. With the V2.6 you will not see that.
Probably a european thing: if it should be like that it must be done like that. Makes life simpler and more organized.
Old 20th March 2013, 03:49 PM   #135
. . . It would have been truly unbelievable if the Subbu V2.6 would have been better than a full grown well designed ES9018 DAC. That is why I am surprised that the Mytek sounds less good. That one has a good reputation.
Jean Paul,
I was also surprised that the Mytek wasn't better. It certainly wasn't bad but didn't knock me out the way I'd expected based on all the glowing reviews. My experience playing with the Buffalo III was that the ES9018 sound is really dependent upon the quality of the output stage. It sounds OK but not a lot better than the ES9023 in voltage mode but it comes alive when forced into current mode.
Well I'll forgive you for being European .
I think we're actually saying similar things, but I'm being very picky about the wording of your messages. Your comments above actually are consistent with what I've been trying to say.
Let me try to explain the way I think about these things. The rise of smart phones and computers that work at clock speeds of >1Ghz have taught the world a lot about noise and how to design electronic systems in small spaces. If you tear apart a smart phone such as an iphone you'll see a lot of shielding but it's all focused on the very high frequency radios (700Mhz, 1.7Ghz, 2.1-2.4Ghz) and the processor (~1Ghz). It's not used for the "lower frequency stuff" running at "only" 50Mhz - 100Mhz. Things running at those frequency always couple their noise through the power grid, so the way of keeping things quiet is to focus on exactly what you did in the v2.6 dac - good power supply decoupling and filtering and regulating.
So when you start saying that the presence of a 50Mhz clock necessitates shielding, I think that you're barking up the wrong tree. You've already solved that problem with your design. You might still want shielding to block magnetic fields from transformers or AC wiring but be sure to use steel or mumetal if you want it to be effective. For DACs, I have not found that hum is a big problem so I don't need shielding for this problem. One might also want shielding to block RF from computers and cell phones from getting into the DAC. But it's really hard to keep RF out of a piece of electronics and I'm doubtful that the typical DIY chassis is actually RF tight. So unless one goes to extremes, I suspect that shielding will just make you feel good and not have any real benefit.
---Gary
Old 20th March 2013, 05:52 PM   #136
Ryssen is online now Ryssen  Sweden
Ryssen's Avatar
Are any component kits left for the old PSU PCB?
As I have one left here.
Regards Åke
Old 20th March 2013, 09:23 PM   #137
jean-paul's Avatar
Originally Posted by GaryB View Post
I'm being very picky about the wording of your messages. Your comments above actually are consistent with what I've been trying to say.---Gary
Gary, please consider that I am a non native english speaker. Let's say that if we had our conversation in dutch or german I could be more clearer. Better be picky about building nice DACs
It is the combination of things and preventive action. Not just the XO possibly straying out but also transformer, RF stray in and AC wiring stray in/hum. I told about experiences with the very first V0 DAC. I also experienced it influenced my tuner when it was nearby (open PCB without a case). I put a lot of time in V2.6 to make it right. Ask Subbu as he probably got very tired when I delivered again a new and better version...
You will need to check with a scope and not just by ears. I see it as a kind of art to build mechanically, electrically and soundwise pleasing. If it is also esthetically pleasing and safe then I did a good job. Same thing like keeping distance between 230 V wiring and output sockets etc. Just do it right at first because you know that doing otherwise is technically less good and maybe it causes problems you need to solve afterwards that will take more time. It will also make you feel good if things are done right. It goes against standard practice of making things just good enough ("how can we get away with it with the least effort at lowest cost?"). That is why DIY audio can be rewarding. No need to save 10 $ cents or 10 minutes, just build the thing the best way you can. Exactly the reason why V2.6 is what it is.
Old 21st March 2013, 10:01 AM   #138
Ryssen's Avatar
I allways "try" to keep the 220v so far away (that is possible)from the amp,DAC,or what I´m building,so that I dont get hum and other interfierence from it.
Regards Åke
Old 24th March 2013, 12:14 PM   #139
tome is offline tome  Macedonia
Thanks J.P. and GaryB for advice, i'll fix the 220v wiring ...
Old 28th March 2013, 01:40 AM   #140
palmito's Avatar
Here's the build I was going to put in a case, but since V3 is coming, I'll wait to put it in the case.
I'm using my spare Jean-Paul ps to power the waveio. Current limit set to 500mA. The heatsink stays at about 45C in the open.
I don't own any hi-end dacs, so I can only compare it to an Endler modfied Behringer DQ2496, a tweaked QNKTC audio widget 1.1 and an Eastern Electric MiniMax (loaned for an extended time). This buid to me sound better than any of the these, deeper more defined bass, more extended and clearer highs. Voices come out clearer, no sibilance.
Thanks again JP and Subbu.
ES9023 / WM8804 S/PDIF DAC Group Buy unixdeveloper Group Buys 683 16th July 2015 07:33 PM
Case for "ES9023 / WM8804 S/PDIF DAC Group Buy" rvrazvan Digital Source 3 27th July 2014 08:37 AM
ES9023 / WM8804 S/PDIF DAC Parts GB EU Only korben69 Group Buys 187 10th October 2012 11:25 AM
Bragi, WM8804/ES9023 DAC Neutrality Digital Line Level 9 22nd September 2012 11:10 AM
FS: Twisted pear audio Dual COD DAC and WM8804 S/PDIF free2dev Swap Meet 4 24th July 2010 12:43 AM
Copyright ©1999-2017 diyAudio
