Group Buys Members group buys
Power Supply PCB for ES9023 / WM8804 S/PDIF DAC Group Buy
Old 7th December 2012, 05:29 PM   #91
presbel is offline presbel  Philippines
Send a message via Yahoo to presbel
Hi Subbu,
I received yesterday the PCB that you sent me in my temporary address in Los Angeles, CA.
Thanks and regards,
Rey
Old 8th December 2012, 05:44 PM   #92
ByronInPortland is offline ByronInPortland  United States
ByronInPortland's Avatar
Originally Posted by korben69 View Post
Hi ryanj
Have a look there : http://www.diyaudio.com/forums/group...ml#post3120349
Forgot to mention that you have to add C13 and Cled, not added in this original BOM.
Cled : 10uF/6.3v - 0805 - X7R - MLCC
C13 : 1uF/25v - 1210 - X7R - MLCC
"Moderator Emeritus" effect
Phil
oh . . . found it.
Old 10th December 2012, 10:10 PM   #93
diy_calderon is offline diy_calderon  United States
in my thickest NY accent "Bawds received!"
Old 29th December 2012, 07:21 PM   #94
palmito is offline palmito  United States
palmito's Avatar
Originally Posted by ByronInLawrence View Post
C13 looks like it might be the same as C2, C4 and C5. Should I use C2, C4 and C5 for C13?
I didn't get C13 either, but got extra C2/C4/C5s like Byron. Can I use the 16v rated C2 instead of the BOM C13 (1uF/25v )? I think in the dac thread someone gave that as a "hint", but just want to be sure.
Thanks.
Old 29th December 2012, 07:27 PM   #95
Ryssen is offline Ryssen  Sweden
Ryssen's Avatar
http://www.diyaudio.com/forums/group...ml#post3262642
Regards Åke
Old 29th December 2012, 07:33 PM   #96
pchw is offline pchw  United States
16V rated is fine for the suggested 8 VAC transformer, and mine is 16V rated.
Even my main shoots up another 30%, it will still be fine, but I am likely to have other gears to blow first :-)
- Fred -
Old 29th December 2012, 10:28 PM   #97
syklab is offline syklab  United States
Thanks.
You should be able to use the same 1uf MLCC 16V or 25V for C2/C4/C5 and C13.
I use flim cap for C2/C4/C5 and MLCC X7R for C13. With our transformer ouput only 8-10V, 16V rating should be good enough.
Old 30th December 2012, 08:38 AM   #98
jean-paul is offline jean-paul  Netherlands
diyAudio Moderator Emeritus
jean-paul's Avatar
Hi I would use 25V versions for all caps before the LM723 like described in the BOM (why deviate from the BOM anyway ?). If the transformer gives around 10V then 15V DC is close to the max. rating of 16V. It will certainly come close to the max. when it is unloaded. Not exactly good design practice, in fact I would call it "potentially unreliable". I like reliable safe good sounding electronics that I can leave powered on if I like. There are too many devices breaking down already so we swim against the current. Good old fashioned fine sounding stuff that lasts......
Strange thing: some want an overdimensioned ttransformer that also gives a too high voltage and at the other hand caps are chosen too tight .
It's only audio. Member of the non modular PCB design committee
Old 30th December 2012, 12:38 PM   #99
palmito's Avatar
Sorry jean-paul, I was confused by the first page BOM (updated 11/30/2012) listing the 25v cap but the Mouser part number in the BOM, for both the standard and alternate caps, pointing to a 16v part. I wrongly assumed the 16v caps would do. I will get 25v parts for all.
Or am I using the wrong BOM?
Happy New Year to all and thanks.
Old 18th January 2013, 11:42 AM   #100
raymondo is offline raymondo  United Kingdom
Subbu received my boards a couple of weeks ago (they arrived at work before xmas but i was off) many thanks - fine quality and working great . Another big thanks to Subbu jean Paul and Phil for the parts . Great work
Power Supply PCB for ES9023 / WM8804 S/PDIF DAC Group BuyHide this!Advertise here!
ES9023 / WM8804 S/PDIF DAC Group Buy unixdeveloper Group Buys 690 14th January 2018 08:46 AM
Case for "ES9023 / WM8804 S/PDIF DAC Group Buy" rvrazvan Digital Source 3 27th July 2014 09:37 AM
ES9023 / WM8804 S/PDIF DAC Parts GB EU Only korben69 Group Buys 187 10th October 2012 12:25 PM
Bragi, WM8804/ES9023 DAC Neutrality Digital Line Level 9 22nd September 2012 12:10 PM
FS: Twisted pear audio Dual COD DAC and WM8804 S/PDIF free2dev Swap Meet 4 24th July 2010 01:43 AM
