Paradise phono stage - Page 98 - diyAudio
Go Back   Home > Forums > Commercial Sector > Group Buys
Group Buys Members group buys
Old 19th February 2013, 12:34 PM   #971
Benedetto's Avatar
Sorry Poul,
but for "aesthetical considerations" i'm looking
for exact those from the GB.
Don't want to mix 'em up.
preregulatorpeterE-MAIL
Old 19th February 2013, 04:20 PM   #972
FdW is offline FdW  Netherlands
FdW's Avatar
Originally Posted by Benedetto View Post
Sorry Poul,
But the GB has 3 or 5mm
Old 19th February 2013, 04:28 PM   #973
Benedetto's Avatar
"Mine" are 5mm...Diffuse Green...
Old 19th February 2013, 04:39 PM   #974
FdW's Avatar
I knew it, they where 3 or 5mm thank you for confirming that
Old 19th February 2013, 04:45 PM   #975
Joachim Gerhard's Avatar
I use this :
Leuchtdioden LEDs Kingbright - hifituning24.de
i think what is more important then size is the specs.
they have to be 2mA high efficiency types
ok, more or less any led will work too. what can happen is that the led string does not produce the required voltage. for example red 2mA types drop around 0.4V less voltage then green ones provided the current is the same. more red ones can then be added for the desired voltage. ricardo uses yellow, amber ones with success. he thinks that they are less noise then the green ones. what sounds better ? i do not know.
Old 19th February 2013, 04:49 PM   #976
FdW's Avatar
Like Joachim said, nearly any green, low current, LED will work. If you need the exact GB LED's maybe a swap with someone that did not yet build.
Old 19th February 2013, 07:09 PM   #977
pdul is offline pdul  Denmark
I use this :
Lets stick with green, using a shuntreg. with a tinch of green technology sounds good Cwhen spoken)
Old 26th February 2013, 06:57 PM   #978
Just making sure: This GB is for phono boards, right?
Old 26th February 2013, 07:03 PM   #979
hesener is offline hesener  Germany
correct. you will receive two boards, two heatsinks, and 12 clips.
Paradise documents are here: Link list
Old 26th February 2013, 08:18 PM   #980
RollE2k is offline RollE2k  Sweden
Added myself to the list!
12az7a phono stage-12ay7a line stage tubenut33 Analog Line Level 1 23rd July 2011 10:44 PM
New Phono Stage Lee35210 Pass Labs 7 19th February 2009 02:30 PM
DIY phono to replace roksan phono stage seroxatmad Analog Line Level 6 14th December 2008 05:46 PM
new phono stage or old preamp with phono? flohmann Analog Line Level 2 2nd October 2008 09:51 PM
Should I replace Scott 222C phono stage with Claret phono stage? Bing Yang Analogue Source 0 22nd August 2005 06:41 AM
Copyright 1999-2017 diyAudio
