Group Buys Members group buys
Paradise phono stage
Old 8th November 2012, 07:41 PM   #791
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Originally Posted by FdW View Post
Here the pictures, Ch1 shorted, Ch2 open, Ch1 20Mhz, Ch2 100Mhz
Thanks. Looks like it has a good front end as DSO's go for noise.
Old 8th November 2012, 07:58 PM   #792
Salas's Avatar
Originally Posted by Joachim Gerhard View Post
Itīs like this.
One possibility that can be transported. The pads can be cut and made smaller or used at the edges.
I use a single, little off centre, screw to tension the PCB safer on the pads when choosing some give in mounting. SYLOMER supporting blocks under green boards in this example.
Old 8th November 2012, 10:29 PM   #793
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
Looks pretty good.
Old 8th November 2012, 10:39 PM   #794
Bksabath is offline Bksabath  United Kingdom
Banned
Here is another one Diy stile
Rubber sheet cut in to circles and srrink sleeve to keep them togheter.
Epoxi resisin is not needed realy
Old 8th November 2012, 10:49 PM   #795
endless creativity
Old 8th November 2012, 10:56 PM   #796
Banned
Not only cheap, they can be tuned with or whitout epoxy and with number of circles or rubber type .
screws or nuts or duble sided stiky tape avvaliable depending on what is in one draw
Nuts
Old 9th November 2012, 08:22 AM   #797
Libby123 is offline Libby123  Germany
I break together - the parts arrived.
Now its getting warm and my solderstation gone wild.
Thanks Hesener, Thanks Birger and Thanks to all the little helpers all around.
Old 9th November 2012, 12:49 PM   #798
Doppelkopf is offline Doppelkopf  Germany
My parts arrived too .
Many many thanks .
greatings , Dirk
Old 10th November 2012, 12:50 PM   #799
kompakt is offline kompakt  Germany
Hello!
I have the board and parts too!
Many thanks for the your exellent job.
Greetings
Seyed
Old 10th November 2012, 02:57 PM   #800
bracla is offline bracla  Germany
Santa Claus was early this year an brought a package from hesener
So Merry Christmas and a Happy New Year to all - I think i have to do some work.
Thanks to all who were and are involved in this project.
Claus
Paradise phono stageHide this!Advertise here!
12az7a phono stage-12ay7a line stage tubenut33 Analog Line Level 1 23rd July 2011 10:44 PM
New Phono Stage Lee35210 Pass Labs 7 19th February 2009 02:30 PM
DIY phono to replace roksan phono stage seroxatmad Analog Line Level 6 14th December 2008 05:46 PM
new phono stage or old preamp with phono? flohmann Analog Line Level 2 2nd October 2008 09:51 PM
Should I replace Scott 222C phono stage with Claret phono stage? Bing Yang Analogue Source 0 22nd August 2005 06:41 AM
