Group Buys Members group buys
Paradise phono stage
Old 8th November 2012, 09:45 AM   #771
Benedetto is offline Benedetto  Germany
Benedetto's Avatar
Originally Posted by Salas View Post
Of course you got metal plated inside by now, no worries.
But as Frans witnessed,
still kinda healthy...
preregulatorpeterE-MAIL
Old 8th November 2012, 09:48 AM   #772
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
@Fdw
That one is a 200MHz Dave's playing with. I wonder if the slower models are any quieter for us analogue low signal level buffs.
Old 8th November 2012, 09:48 AM   #773
FdW is offline FdW  Netherlands
FdW's Avatar
I second that
Old 8th November 2012, 09:49 AM   #774
Salas's Avatar
Iron man.
Old 8th November 2012, 09:52 AM   #775
FdW's Avatar
The one 100Mhz one or the 70Mhz one are the same, they only have a fixed analog filter. The filter is not software controlled and you cannot upgrade (like in the previous models) the bandwidth. When bandwidth limited to 20Mhz I doubt that you will see the/a difference between the 200 and the 70Mhz versions. I will produce that picture.
Old 8th November 2012, 09:58 AM   #776
Salas's Avatar
I already got a 100MHz 1000 series so 200MHz would be optimum but they pound with pricing there.
Old 8th November 2012, 10:00 AM   #777
FdW's Avatar
I think the real difference is the 12bit capability, especially when producing FFT's. That is why I got a DS2000 version.
Old 8th November 2012, 10:58 AM   #778
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
Yes, there are no holes drilled in the corners. Some people may mount the PCBs not with screws so we did not drill the holes but you can before mounting the components.
The pad coating is galvanic silver.
Old 8th November 2012, 11:47 AM   #779
Salas's Avatar
Like how? Soft pads for resilient mounting?
Old 8th November 2012, 12:01 PM   #780
Yes, there are foamed rubber pads with a slot i use sometimes. I make a photo.
Paradise phono stageHide this!Advertise here!
12az7a phono stage-12ay7a line stage tubenut33 Analog Line Level 1 23rd July 2011 10:44 PM
New Phono Stage Lee35210 Pass Labs 7 19th February 2009 02:30 PM
DIY phono to replace roksan phono stage seroxatmad Analog Line Level 6 14th December 2008 05:46 PM
new phono stage or old preamp with phono? flohmann Analog Line Level 2 2nd October 2008 09:51 PM
Should I replace Scott 222C phono stage with Claret phono stage? Bing Yang Analogue Source 0 22nd August 2005 06:41 AM
